I need to pick your brains #662865
04/06/10 07:53 PM
04/06/10 07:53 PM
Seaford, Va
Kindafast Offline OP
Seaford, Va
Hey everyone I am having a wierd problem and I hope you can help. I got my new shortblock in about the same time I bought a new 950Hp carb, so it's been a little while getting everything working right. The engine runs fine and the carb seems to run great until it's run for a while. I can drive this thing around for about five miles and it runs fine , but when it runs a little longer than that it acts like it's flooding out to the point of cutting off. I can shut the fuel pump off and it will run fine until it starts to run out of gas. I have changed the fuel pressure, adjusted the float levels and everything I can think of but nothing helps. If I didn't give a acurate enough symptons just ask. Thanks for your help. Joe
6.50 @105.26
Re: I need to pick your brains [Re: Kindafast] #662866
04/06/10 07:57 PM
04/06/10 07:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Maybe its just getting to hot... try a wood spacer
under the carb to see if that helps
Re: I need to pick your brains [Re: Kindafast] #662867
04/06/10 08:25 PM
04/06/10 08:25 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Makes me think you got a coil breaking down..not enuff spark..so you think it is rich..
Re: I need to pick your brains [Re: MR_P_BODY] #662868
04/06/10 08:36 PM
04/06/10 08:36 PM
Seaford, Va
Seaford, Va
Thanks Mr P. I thought that also but the carb don't get that warm. It has a Super Sucker spacer on it also.
6.50 @105.26
Re: I need to pick your brains [Re: VernMotor] #662869
04/06/10 08:39 PM
04/06/10 08:39 PM
Seaford, Va
Seaford, Va
My son said the same thing about the coil. But why would it run fine as soon as I turned the fuel pump off.
6.50 @105.26
Re: I need to pick your brains [Re: Kindafast] #662870
04/06/10 08:55 PM
04/06/10 08:55 PM
whats your fuel pressure set at?
sounds to me you got a stuck needle and seat.
Re: I need to pick your brains [Re: Kindafast] #662871
04/06/10 09:04 PM
04/06/10 09:04 PM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
Shutting the fuel pump off would send more voltage to the coil, which could potentially make it operate better? Not saying that is your problem, just a thought...I recently had a coil go bad, and it worked fine for about 5 minutes at which time it would get extremely hot. (turned out to be the wrong coil for my ignition box)
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: I need to pick your brains [Re: Kindafast] #662872
04/06/10 09:05 PM
04/06/10 09:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Ok so its not getting too hot.... it could be coil
BUT since you arent shutting the car off just turning
the pump off till it starts to stumble(at least thats
what I'm guessing your doing) then turning the pump
back on.... if this is the case I wouldnt think coil
(it didnt have time to cool)... could be a needle
expanding and not sealing... that would be a cheap
check, try a viton needle... but it would sound like
a fuel issue.... but electronics will act weird once
heated and go back to normal once cooled, but your
not giving it cool time
Re: I need to pick your brains [Re: MR_P_BODY] #662873
04/06/10 09:22 PM
04/06/10 09:22 PM
Seaford, Va
Seaford, Va
Thanks for all the replys. Mr P You are right I don't shut the car off I just shut the fuel pump off and it runs fine until it starts running out of gas. Then I turn the fuel pump on and it fills up the bowls and starts running like poop again. I am open to all possibilities at this point keep them comming.
6.50 @105.26
Re: I need to pick your brains #662874
04/06/10 09:23 PM
04/06/10 09:23 PM
Seaford, Va
Seaford, Va
I have backed the fuel pressure down as low as 4.5 lbs and it really don't change.
6.50 @105.26
Re: I need to pick your brains [Re: Kindafast] #662875
04/06/10 09:25 PM
04/06/10 09:25 PM
UK
602heavy Offline
602heavy  Offline
UK
Needle & seats. is the fuel pressure gauge reading ok?
Re: I need to pick your brains [Re: 602heavy] #662876
04/06/10 09:36 PM
04/06/10 09:36 PM
Seaford, Va
Seaford, Va
I bought a new gauge today just to make sure.
Needle and seats are kind of what I am thinking too.
6.50 @105.26
Re: I need to pick your brains [Re: Kindafast] #662877
04/06/10 09:56 PM
04/06/10 09:56 PM
MotorCity
RC91 Offline
RC91  Offline
MotorCity
Check your secondary needle & seat. If it's leaking just a little, fuel could be dripping down the secondaries causing the crappy running. Shutting the pump off causes it to level out and quit dripping.
Re: I need to pick your brains [Re: Kindafast] #662878
04/06/10 10:24 PM
04/06/10 10:24 PM
Elbridge, NY
Dart1031 Offline
Dart1031  Offline
Elbridge, NY
What about a leaking/blown power valve? When it's cold it needs the extra fuel. When it's warm it's running rich and stumbling.
Re: I need to pick your brains [Re: RC91] #662879
04/06/10 10:31 PM
04/06/10 10:31 PM
UK
602heavy Offline
602heavy  Offline
UK
Bad pump umbrellas can cause fuel to exit over boosters/vents when you stomp on it , could also be fuel pullover from squirters if check valves are missing/not seated , are bowl vents clear? , have sec jets had extentions fitted along with correct floats? , stuck floats? ................just some things to check.
Re: I need to pick your brains [Re: Kindafast] #662880
04/06/10 10:46 PM
04/06/10 10:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Have you looked down the carb when the problem is
happening, you might get some insight to the problem
Re: I need to pick your brains [Re: MR_P_BODY] #662881
04/07/10 07:42 AM
04/07/10 07:42 AM
Seaford, Va
Seaford, Va
No I don't get a chance to do that. I did notice the front and rear butterfly areas had a lot of fuel in them when it did cut off.
Thanks for all the advice and I am going to try and figure it out later today. I will keep you posted.
6.50 @105.26
Re: I need to pick your brains [Re: Kindafast] #662882
04/07/10 10:56 AM
04/07/10 10:56 AM
organ
maximum entropy Offline
organ
what kind of gas are you running? pump gas nowadays will boil at a very low temperature. i had pump gas (ethanol free) boiling at what felt like about 120 degrees! the carb was barely warm, and the gas was boiling violently! car ran like poopy.
Re: I need to pick your brains [Re: maximum entropy] #662883
04/07/10 04:57 PM
04/07/10 04:57 PM
Seaford, Va
Seaford, Va
Ok I messed with it all day. I did get the carb to duplicate the problem in the garage. I found if I get the engine nice and hot and drop it in gear and stand on the brake to about 2200 rps it will start to shoot fuel from the front vent tube. I can rev it up and it stops and if I let it go back to a idle it will stop. This is driving me crazy. Any more ideas ?
6.50 @105.26
Re: I need to pick your brains [Re: Kindafast] #662884
04/07/10 04:59 PM
04/07/10 04:59 PM
organ
organ
do you have clear sight plugs? if so, see if the fuel is boiling.
