I need to pick your brains
#662865
04/06/10 07:53 PM
04/06/10 07:53 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Hey everyone I am having a wierd problem and I hope you can help. I got my new shortblock in about the same time I bought a new 950Hp carb, so it's been a little while getting everything working right. The engine runs fine and the carb seems to run great until it's run for a while. I can drive this thing around for about five miles and it runs fine , but when it runs a little longer than that it acts like it's flooding out to the point of cutting off. I can shut the fuel pump off and it will run fine until it starts to run out of gas. I have changed the fuel pressure, adjusted the float levels and everything I can think of but nothing helps. If I didn't give a acurate enough symptons just ask. Thanks for your help. Joe
6.50 @105.26
Re: I need to pick your brains
[Re: MR_P_BODY]
#662868
04/06/10 08:36 PM
04/06/10 08:36 PM
Kindafast
Seaford, Va
Thanks Mr P. I thought that also but the carb don't get that warm. It has a Super Sucker spacer on it also.
6.50 @105.26
[Re: VernMotor]
#662869
04/06/10 08:39 PM
04/06/10 08:39 PM
Kindafast
Seaford, Va
My son said the same thing about the coil. But why would it run fine as soon as I turned the fuel pump off.
6.50 @105.26
[Re: Kindafast]
#662870
04/06/10 08:55 PM
04/06/10 08:55 PM
whats your fuel pressure set at? sounds to me you got a stuck needle and seat.
[Re: Kindafast]
#662872
04/06/10 09:05 PM
04/06/10 09:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ok so its not getting too hot.... it could be coil BUT since you arent shutting the car off just turning the pump off till it starts to stumble(at least thats what I'm guessing your doing) then turning the pump back on.... if this is the case I wouldnt think coil (it didnt have time to cool)... could be a needle expanding and not sealing... that would be a cheap check, try a viton needle... but it would sound like a fuel issue.... but electronics will act weird once heated and go back to normal once cooled, but your not giving it cool time
[Re: MR_P_BODY]
#662873
04/06/10 09:22 PM
04/06/10 09:22 PM
Kindafast
Seaford, Va
Thanks for all the replys. Mr P You are right I don't shut the car off I just shut the fuel pump off and it runs fine until it starts running out of gas. Then I turn the fuel pump on and it fills up the bowls and starts running like poop again. I am open to all possibilities at this point keep them comming.
6.50 @105.26
[Re: Kindafast]
#662882
04/07/10 10:56 AM
04/07/10 10:56 AM
Posts: 5,080 organ
maximum entropy
organ
what kind of gas are you running? pump gas nowadays will boil at a very low temperature. i had pump gas (ethanol free) boiling at what felt like about 120 degrees! the carb was barely warm, and the gas was boiling violently! car ran like poopy.
[Re: maximum entropy]
#662883
04/07/10 04:57 PM
04/07/10 04:57 PM
Kindafast
Seaford, Va
Ok I messed with it all day. I did get the carb to duplicate the problem in the garage. I found if I get the engine nice and hot and drop it in gear and stand on the brake to about 2200 rps it will start to shoot fuel from the front vent tube. I can rev it up and it stops and if I let it go back to a idle it will stop. This is driving me crazy. Any more ideas ?
6.50 @105.26
[Re: Kindafast]
#662884
04/07/10 04:59 PM
04/07/10 04:59 PM
Posts: 5,080 organ
maximum entropy
organ
do you have clear sight plugs? if so, see if the fuel is boiling.
