flywheel and pressure plate question #661924
04/05/10 09:15 PM
04/05/10 09:15 PM
South San Francisco, Ca
70sixpkrt Online content OP
70sixpkrt  Online Content OP
I am doing a clutch job on my Charger and just wondering after I get my flywheel resurfaced, what is good to clean the flywheel and pressure plate with? I heard nail polish remover on a paper towel is good. Just double checking.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: flywheel and pressure plate question [Re: 70sixpkrt] #661925
04/05/10 09:22 PM
04/05/10 09:22 PM
brake kleen or starting fluid w some paper towels is fine and I'd not clean them until the 'wheel is on and you are ready to bolt the disc/pp up there that way you clean them of oils and your fingerprints at the same time. EDIT a buck fifty can of spray starting fluid will clean the disc and if it's going to be awhile 'till you go together (which I dont is the case here) leaving everything oily will keep them from flash rusting and as you know dont let any oil/grease get near the disc surfaces as it will soak in
Re: flywheel and pressure plate question [Re: RapidRobert] #661926
04/06/10 05:53 PM
04/06/10 05:53 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
I wouldn't use starting fluid as a degreaser, some brands contain an upper cylinder lubricant for ring protection.
Re: flywheel and pressure plate question [Re: John_Kunkel] #661927
04/06/10 11:43 PM
04/06/10 11:43 PM
Rome, GA
GTXX Offline
GTXX  Offline
Rome, GA
nail polish remover can have stuff in it to keep from drying skin. plain old rubbing alcohol is clean, laquer thinner, acetone are good too.
'71 GTX w/Air Grabber, Super Trak Pak, Spoiler Pkg. been apart for 22 years, thinking it's time to do something about that....
Re: flywheel and pressure plate question [Re: GTXX] #661928
04/07/10 09:27 AM
04/07/10 09:27 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree Brake clean.Ive used that only for years.Other stuff can have additives.Starting fluid is bad stuff.One spark while cleaning and poof.You are on fire especially if you are in a building.Rocky
Chrysler Firepower
Re: flywheel and pressure plate question [Re: therocks] #661929
04/07/10 10:22 AM
04/07/10 10:22 AM
Alright I'll ditch the starting fluid
Re: flywheel and pressure plate question [Re: RapidRobert] #661930
04/07/10 09:39 PM
04/07/10 09:39 PM
Brake cleen it is.
4-speed
3:54 Dana
