Re: flywheel and pressure plate question
[Re: 70sixpkrt]
#661925
04/05/10 09:22 PM
04/05/10 09:22 PM
RapidRobert
brake kleen or starting fluid w some paper towels is fine and I'd not clean them until the 'wheel is on and you are ready to bolt the disc/pp up there that way you clean them of oils and your fingerprints at the same time. EDIT a buck fifty can of spray starting fluid will clean the disc and if it's going to be awhile 'till you go together (which I dont is the case here) leaving everything oily will keep them from flash rusting and as you know dont let any oil/grease get near the disc surfaces as it will soak in
[Re: RapidRobert]
#661926
04/06/10 05:53 PM
04/06/10 05:53 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I wouldn't use starting fluid as a degreaser, some brands contain an upper cylinder lubricant for ring protection.
[Re: John_Kunkel]
#661927
04/06/10 11:43 PM
04/06/10 11:43 PM
Posts: 176 Rome, GA
GTXX
Rome, GA
nail polish remover can have stuff in it to keep from drying skin. plain old rubbing alcohol is clean, laquer thinner, acetone are good too.
'71 GTX w/Air Grabber, Super Trak Pak, Spoiler Pkg. been apart for 22 years, thinking it's time to do something about that....
[Re: GTXX]
#661928
04/07/10 09:27 AM
04/07/10 09:27 AM
Posts: 21,065 Niles , Ohio
therocks
Niles , Ohio
I agree Brake clean.Ive used that only for years.Other stuff can have additives.Starting fluid is bad stuff.One spark while cleaning and poof.You are on fire especially if you are in a building.Rocky
Chrysler Firepower
[Re: therocks]
#661929
04/07/10 10:22 AM
04/07/10 10:22 AM
RapidRobert
Alright I'll ditch the starting fluid
