Re: Oil pressure issues STILL !!!!! Help needed [Re: sc301v] #661441
04/07/10 06:45 AM
04/07/10 06:45 AM
i've used those exact lifters in unbushed blocks a number of times and have never experienced the type of problem you describe.
basically you have a bunch of "controlled" leaks, (i.e. oil to the roller and pushrod oiling.)it's not likely your uncovering the oil gallery, but did you check when installing the lifters? what was your measured lifter to bore clearance during installation? without that information, one could only guess at where the problem may be IMO. is it time for a better pump? the dual line is great, but is the pump itself capable of supplying the volume you need? the dual line is on the INPUT side of the pump, not the OUTPUT.
my guess is that in order to actually fix the problem, you'll have to start investigating all area's of the oiling system and critical dimensons and clearances.
Re: Oil pressure issues STILL !!!!! Help needed #661442
04/07/10 07:32 AM
04/07/10 07:32 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Lots of good ideas here but, I didn't see anyone suggest looking at the oil PRV circuit...It may be a simple solution. I know noone has problems with Milodon pumps... ...but every once in a blue moon something can go wrong. It'd be simple enough to check anyway.
Re: Oil pressure issues STILL !!!!! Help needed #661443
04/07/10 07:50 AM
04/07/10 07:50 AM
MotorCity
RC91 Offline
RC91  Offline
MotorCity
Is there possibly a diamond shaped stamp on the block number pad denoting .008 oversized lifter bores? (I would hope not on a mega block, but...)
Re: Oil pressure issues STILL !!!!! Help needed [Re: sc301v] #661444
04/07/10 01:07 PM
04/07/10 01:07 PM
Verify the gauge, check it agianst another known accurate gauge BTW what is your idle speed?
Re: Oil pressure issues STILL !!!!! Help needed [Re: Cab_Burge] #661445
04/07/10 03:02 PM
04/07/10 03:02 PM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Cab the idle speed is around 12 and 1300
Re: Oil pressure issues STILL !!!!! Help needed [Re: sc301v] #661446
04/08/10 12:25 AM
04/08/10 12:25 AM
Is this a aluminum block?
Re: Oil pressure issues STILL !!!!! Help needed [Re: Cab_Burge] #661447
04/08/10 08:29 AM
04/08/10 08:29 AM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Nope its steel
Re: Oil pressure issues STILL !!!!! Help needed [Re: sc301v] #661448
04/08/10 09:59 AM
04/08/10 09:59 AM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Last season before a roller lifter went out and got in my oil pump. With the Indy single line pump(with 2 washers on the pressure spring) and dragster pan I had 80 lbs @ idle Hot & Cold when you revved the engine it would go up to 100 lbs.
So my question is have you took your pickup out and checked it? I had cleaned my oil pan before,but never took the pickup out. Could something be blocking some of the opening?
I hope to get my heads back in a few days. I have already made a mistake before I start back on the engine. I was sure my engine did not oil thru the lifters and push rods,but it does.
It would be nice if all of us could make a list of things to check are do before building our engines. I know I had rather spend a little more time and money now than have to go back later hunting things to fix.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: Oil pressure issues STILL !!!!! Help needed [Re: MRMOPAR622] #661449
04/08/10 11:09 AM
04/08/10 11:09 AM
Kentucky
sc301v Offline OP
sc301v  Offline OP
Kentucky
Yes the pickup has been takin out and cleaned thourghly when i had it apart this winter..
Re: Oil pressure issues STILL !!!!! Help needed [Re: sc301v] #661450
04/08/10 04:05 PM
04/08/10 04:05 PM
Nope its steel
I don't have any other thoughts on this, please let us know what you find that caused this problem. (maybe check that gauge )
Re: Oil pressure issues STILL !!!!! Help needed [Re: Cab_Burge] #661451
04/08/10 04:31 PM
04/08/10 04:31 PM
UK
602heavy Offline
602heavy  Offline
UK
SC30 , i have the same set up as you . also had the same issues as you're having , i got there in the end as i'm sure you will , get the motor on the engine stand & figure where the excessive leak down is & i'm sure you'll fix the problem , when you prime the motor it should all come clear.
As i said previously in this post , the oil pump mod netted an increase in oil pressure of around 10/15psi.
Good luck.
Re: Oil pressure issues STILL !!!!! Help needed [Re: 602heavy] #661452
04/08/10 08:40 PM
04/08/10 08:40 PM
mo
moparbud Offline
moparbud  Offline
mo
my 500ci and indy sr heads was doing the same thing 75psi cold and 10psi hot i used holley jets to restrict the oil flow to the rocker shafts have good oil psi now
