1.550 valv e springs, 250+seat and 700+ open?Update #661256
04/05/10 12:07 AM
04/05/10 12:07 AM
Cab_Burge Offline OP
I'm looking for a new set of valve springs that need to be 1.50 to 1.56 O.D. installed at around 1.950 installed hieght that I can get 680 + lbs open pressure with .730 net lift
I'm using a set of T&D rockers and can not use the 1.625 O.D. springs on that set I called and ordered a set of the PAC 1225 dual valve springs for my motor direct from PAC Very easy to deal with THANKS TO ALL OF YOU FOR THE HELP. The 527 will run again and hopefully make power at a higher RPM These springs call for a installed hieght of 2.00 with 250 lbs seat pressure they show 765 lbs open pressure at 1.200 or .800 lift. I will play around with the install hieght and the coil bind distance to get the most pressures I can. I'm shooting for .060 to .080 from coil bind on the open hieghts. My current installed hieght is 1.960 to 1.980 with the Comp Tititanium 10 degree retainers, I'm hoping they will work if not I guess it is time to buy the correct ones I'm also planning on replacing the 3/8x.120 wall pushrods with some thicker, stiffer ones
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Cab_Burge] #661257
04/05/10 12:27 AM
04/05/10 12:27 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
tough call Cab, couldn't find anything on comp cams site, why can't you remachine for 1.62 dia?
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Cab_Burge] #661258
04/05/10 12:31 AM
04/05/10 12:31 AM
Alberta Canada
StrokerAspen Offline
Alberta Canada
I am in the same boat.
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Cab_Burge] #661259
04/05/10 12:59 AM
04/05/10 12:59 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
have a look at crane's 96886-16 they are a bit heavyer over the nose but there might be somthing in the area your looking for, my machine shop told me to use isky tool room springs with my roller
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Cab_Burge] #661260
04/05/10 01:22 AM
04/05/10 01:22 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I am using the PAC-1225 springs.
http://www.pacracing.com/1200_Series-Dual_Springs.html
OD = 1.550", 250# at 2.00", 765# at 1.20" rated for 0.800" lift.
I don't have the part number handy, but I used Crower +0.100" height Ti retainers to get 1.950" install height. I think the closed pressure at 1.950" is around 270-275. Originally I had also used +0.050" locks to get 2.00" install height, but my T&D rockers would not clear the retainer. It would probbably work if I was using lash caps, but then I would have to get shorter pushrods.
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: 451Mopar] #661261
04/05/10 05:31 AM
04/05/10 05:31 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
I never understood why people say T&D's are better than harlands........
Mopar Performance
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: moparniac] #661262
04/05/10 07:27 AM
04/05/10 07:27 AM
Arizona
Chris'sBarracuda Offline
Happy Birthday Chris'sBarracuda  Offline
Arizona
Well silly, it's because they are..
Not opinion, just a fact..
BTW. I use 1.625 Erson/Nextek on my T&D set up.. no issues..
Just get the right retainer.
This is a B1 with over .830 lift. 285# seat & 810# open.. 2.050 installed ht.
#1224 or #1324 pac would be the best choice at that size, but the pac #1225 1.550 is a really good spring also.
Chris..
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Chris'sBarracuda] #661263
04/05/10 09:15 AM
04/05/10 09:15 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
A friend of mine just got a set of Isky's expensive but with close to those specs 9968-RAD
250 @ 1.950 and 670 @ 1200 could bind 1100.
http://www.iskycams.com/springbook.pdf
If you phone Isky ask for Ron the other guy bassicaly wants to hang up right away!!!
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Cab_Burge] #661264
04/05/10 10:35 AM
04/05/10 10:35 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Cab,
Take a look at Comp 999. I have have had really good luck with these and have an orphaned set, cheap. Managet to get to 8K with SS valves and a tame ramp.
Mike
8.30's @3400 lbs
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Chris'sBarracuda] #661265
04/05/10 11:59 AM
04/05/10 11:59 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Chris..
does anyone have any facts on this or us it like saying one oil is better than the other from engine failure.
Mopar Performance
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Mike Swann] #661266
04/05/10 12:01 PM
04/05/10 12:01 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
comp 944's @ 1.89
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: 451Mopar] #661267
04/05/10 01:30 PM
04/05/10 01:30 PM
That looks like the answer I have a set of Comp Cams on there now, they set up at 275 on the seat and 670 to 680 over the nose new. This is on my 527 motor that I have been dyno testing carbs and intakes on. I lost two pistons in it due to detonation and I'm putting it back together now, the springs lost around 25 lbs on the seat and over the nose. The motor made peak HP around 6500 RPM and I'm wanting to push that higher so the quest for a better valve spring. Last question, I hope, who has the best deal on those valve springs? Thanks to all of you, together we can help each other
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Cab_Burge] #661268
04/05/10 02:07 PM
04/05/10 02:07 PM
Missouri
galen Offline
galen  Offline
Missouri
Cab I just got rid of a set of K-motion K950s . 1.550 diam. 2" installed height. 245 lbs. seat. 690lbs. at 1.3. At 1.250 I was well over 700 lbs on my tester at .730. Coil bind 1.150. They are a H11 tool steel spring. I ran a set of plus .050 locks put me at 2".
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Cab_Burge] #661269
04/05/10 03:12 PM
04/05/10 03:12 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
PAC springs ARE the answer.
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: jim sciortino] #661270
04/05/10 03:25 PM
04/05/10 03:25 PM
ms
W
w2dak394 Offline
w2dak394  Offline
W
ms
Just bought a set for my w2 heads. Made by comp cams they were less than 200.00 from Barker automotive. You have to buy them on ebay and they will ship from comp.
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: 451Mopar] #661271
04/05/10 03:35 PM
04/05/10 03:35 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Thus, introducing 2 errors.
If the geo is already correct (but clearance is not) lash caps require stand shims and longer pushrods.
Boffin Emeritus
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: moparniac] #661272
04/05/10 05:35 PM
04/05/10 05:35 PM
Arizona
Arizona
Chris..
Just look at the valvetrain on Pro Stock and Comp cars.
I'll bet you see Jesel or T&D.
And I'll also bet you wont find any Harland Sharps on those engines.. That to me, would be fact..
Chris..
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Chris'sBarracuda] #661273
04/05/10 05:39 PM
04/05/10 05:39 PM
Hemiroid Offline
Hemiroid  Offline
Chris..
Chris..
You may see Wilfords stuff and Jesel, but I don't think T&Ds stuff is in PS. That being said, T&D is a great rocker and is on a lot of very fast cars.
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Hemiroid] #661274
04/06/10 03:06 PM
04/06/10 03:06 PM
I bought a set of the PAC springs, see the first post for the details. Thanks to all for the help
Re: 1.550 valv e springs, 250+seat and 700+ open? [Re: Cab_Burge] #661275
04/06/10 03:18 PM
04/06/10 03:18 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
has anyone heard of pbm??im not 100% sure...i had new springs put on the hemi and this was the box he sent my old springs/retainers/locks back in the springs are 1.550 o.d. dual springs part # was 3840 210#@1.90 660#1.200 700 max lift 1.100 coil bind the car is solid roller with right at 600 lift is these springs worth a crap? what kind of rpm would this combo be good for (426 hemi alum rods)
sory for the hi-jack
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
