Piston out of the hole .022 #661238
04/04/10 11:33 PM
04/04/10 11:33 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
Wondering what your thoughts are on the following scenario.
Piston .022 out of the hole, with .290 from the crown of the piston to the top ring.
Ive already got some .062 Cometics so that should work out nicely.
Just wondering if that is too far out of the hole?
KB says it will be fine, but....
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Piston out of the hole .022 [Re: Von] #661239
04/04/10 11:41 PM
04/04/10 11:41 PM
IN
Irun5snd8th Offline
Irun5snd8th  Offline
IN
Run my small block with .020 out of the hole and .060 cometics. Not issues at 12.8:1
AFCO, Rons Fuel Injection sponsored Dodge Challenger Mention Street Lethal Motorsports
Re: Piston out of the hole .022 [Re: Von] #661240
04/04/10 11:41 PM
04/04/10 11:41 PM
which head and chamber design? Sounds like that motor is going to have some compression
Re: Piston out of the hole .022 [Re: Cab_Burge] #661241
04/04/10 11:58 PM
04/04/10 11:58 PM
NE Oklahoma
V
Von Offline OP
Von  Offline OP
V
NE Oklahoma
BS heads, and about 12.7 comp. Using a dish to keep the compression reasonable.
Re: Piston out of the hole .022 [Re: Von] #661242
04/05/10 12:01 AM
04/05/10 12:01 AM
Mock that rascal up with some clay around the valve reliefs, set the heads on with bolts and head gasksets, set the valve lash and check it out, your probally golden but it doesn't hurt to check
Re: Piston out of the hole .022 [Re: Von] #661243
04/05/10 12:42 AM
04/05/10 12:42 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i'm out of the hole .040 Von, cometic gaskets work a treat for me in this situation.
