Re: Rocker arm adjuster question
[Re: Hunted Duck]
#661014
04/04/10 09:47 PM
04/04/10 09:47 PM
Posts: 43,129 Bend,OR USA
Cab_Burge
Both can be abused and broken if the lengths are not correct. How many threads are showing between the rocker arm bottom and the ball on the adjuster?
[Re: Hunted Duck]
#661017
04/04/10 10:46 PM
04/04/10 10:46 PM
Cab_Burge
Whose pushrods, brand, wall thickness and diameter are you using and do you know how much spring pressure you have both opened and closed? EDIT, is there any sign of the pushrod cup hitting the rocker arm or the adjusters?
