Is there a rule of when a fluid drive cooling fan #660650
04/04/10 03:22 PM
04/04/10 03:22 PM
Ont, Canada
gygeneral Offline OP
Ont, Canada
clutch was used as opposed to simply having a spacer with the fan. I have a 70 challenger 383 and trying to determine how it would have come with.
Also like to mention that the FSM references cars with air conditioning have the fluid drive fan, no mention of HP cars.
Thanks Norm
Re: Is there a rule of when a fluid drive cooling fan [Re: gygeneral] #660651
04/04/10 07:19 PM
04/04/10 07:19 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
It is usually associated with the heavy duty or max cooling. A 22" radiator'd 383 is fixed & a 26" radiator'd 383 has a clutch fan.
Re: Is there a rule of when a fluid drive cooling fan [Re: 6bblgt] #660652
04/04/10 07:55 PM
04/04/10 07:55 PM
Ont, Canada
Ont, Canada
Thanks, that makes sense.
Re: Is there a rule of when a fluid drive cooling fan [Re: gygeneral] #660653
04/06/10 05:01 AM
04/06/10 05:01 AM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
The A/C cars used the thermostatically controlled fan drive (spring in the middle of the drive hub). The performance cars without A/C used the fluid drive.
It is listed on the Broadcast sheet.
Re: Is there a rule of when a fluid drive cooling fan [Re: Snoopy] #660654
04/06/10 09:00 AM
04/06/10 09:00 AM
Ont, Canada
Ont, Canada
Snoopy, was there a definition of what a high performance car was???? Or when did a car just get a solid fan with the spacer??
Re: Is there a rule of when a fluid drive cooling fan [Re: gygeneral] #660655
04/06/10 11:05 AM
04/06/10 11:05 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I think that you can see that it's determined by engine size, AC and axle package.
morty
Re: Is there a rule of when a fluid drive cooling fan [Re: Snoopy] #660656
04/06/10 12:01 PM
04/06/10 12:01 PM
Ont, Canada
Ont, Canada
I found the code 24 in the fan box on my b/s. I guess that means it came with the 2863224 fan which is the fan with the spacer.
Re: Is there a rule of when a fluid drive cooling fan [Re: gygeneral] #660657
04/06/10 01:51 PM
04/06/10 01:51 PM
Snoopy Offline
Snoopy  Offline
Look in the box next to the fan, (FAN SPA).
Re: Is there a rule of when a fluid drive cooling fan [Re: Snoopy] #660658
04/06/10 03:52 PM
04/06/10 03:52 PM
Ont, Canada
Ont, Canada
Looks like a 10 in that box. What does that mean??
Re: Is there a rule of when a fluid drive cooling fan [Re: gygeneral] #660659
04/06/10 04:01 PM
04/06/10 04:01 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
2120 510 spacer 1.60" lg. - on SNOOPY's list
Re: Is there a rule of when a fluid drive cooling fan [Re: 6bblgt] #660660
04/06/10 04:57 PM
04/06/10 04:57 PM
Ont, Canada
Ont, Canada
Thanks everyone, I learnt something new
