Page 3 of 3 1 2 3
Re: Freeing stuck fuel pump pushrod [Re: riverman] #660098
04/27/10 02:44 PM
04/27/10 02:44 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Two days - no response. No thank you, we will look into it, etc.
Well, Their response to me was it must have been something I did wrong lubrication, wrong spring pressure on my fuel pump, bad eccentric on cam. So I gave them the benefit of the doubt and checked all. Used Valvoline VR1 With a zinc additive as well. Plenty of lube. Stock fuel pump and the eccentric was perfect. So buyer beware! Pretty sad customer service.
Re: Freeing stuck fuel pump pushrod [Re: ireland383] #660099
04/27/10 03:38 PM
04/27/10 03:38 PM
New Zealand
nz383man Offline
nz383man  Offline
New Zealand
Cheers for the feedback,
I was very interested to hear what they had to say.
Re: Freeing stuck fuel pump pushrod [Re: ireland383] #660100
04/28/10 09:00 AM
04/28/10 09:00 AM
Eastern North Carolina
riverman Offline
riverman  Offline
I received no return message. (and i did not ask for anything but a reply) Well maybe someone will buy one of these rods, does something to their engine and then Mancini receives a lawsuit letter. That might get their attention.
Re: Freeing stuck fuel pump pushrod [Re: riverman] #660101
04/28/10 05:19 PM
04/28/10 05:19 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
I just got an email saying to return the rod for a refund or store credit. I guess it pays to complain. Shipping is $5 bucks for a $15 part.
Re: Freeing stuck fuel pump pushrod [Re: beatgoeson] #1910042
09/10/15 05:23 PM
09/10/15 05:23 PM
colorado
68charger440strk Offline
colorado
Old thread, but I just had my original pushrod eaten up by my Carter high volume pump, so beware if you are running those pumps. I checked the specs on the pushrod when I installed the carter about 3000 miles ago and it was within specs. Now it is only 3" long and shot, and like I said that was an original pushrod, not a replacement. I have seen now that others have had problems with the carter high volume pumps being too stiff, and eating pushrods.
Re: Freeing stuck fuel pump pushrod [Re: beatgoeson] #1910389
09/11/15 03:55 AM
09/11/15 03:55 AM
massachusetts U.S.A.
1969ronnie Offline
1969ronnie  Offline
68, what oil are you running , brand and weight? {original 68 pushrod lasted 40 years}? ronnie
Re: Freeing stuck fuel pump pushrod [Re: 1969ronnie] #1910671
09/11/15 06:07 PM
09/11/15 06:07 PM
New Mexico
JMCFAN Online content
JMCFAN  Online Content
New Mexico
I did find that 440source is currently selling some original Chrysler pump rods refinished....After reading this thread I am ordering one before I put the engine in the RR... i will eat the $15 I spent at Rock Auto....
68 Charger 383/ AT Green/Green VT
70 Roadrunner 383/4sp Purple/Black VT
Re: Freeing stuck fuel pump pushrod [Re: beatgoeson] #1910957
09/12/15 05:42 AM
09/12/15 05:42 AM
St. Paul, Mn.
Jim_S Offline
Jim_S  Offline
St. Paul, Mn.
I put one of these in my 383 from Hughes Engines.
Hardened fuel pump push rod.
It is part number HUG 10010
http://www.hughesengines.com/Index/products.php?browse=search&search=fuel+pump+push+rod
69 Roadrunner 383 stock
Re: Freeing stuck fuel pump pushrod [Re: beatgoeson] #1911132
09/12/15 03:55 PM
09/12/15 03:55 PM
Dr Dave Offline
Dr Dave  Offline
Moroso makes a rod with hardend ends for BB
Re: Freeing stuck fuel pump pushrod [Re: beatgoeson] #1911471
09/13/15 03:06 AM
09/13/15 03:06 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
I bought one of ebag from Rick Ehrenberg part#2463921 he claims NOS OEM hardened steel Max Wedge/426 Hemi pushrod $36.00.I don't see any rings on the end/tip of it.
Re: Freeing stuck fuel pump pushrod [Re: 71GTX471] #1911723
09/13/15 04:35 PM
09/13/15 04:35 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Just wanted to chime in and say that I had a comp cams pushrod go south in under 300 miles last year. They had no explanation but offered me a free replacement. I said NO THANKS! Dug into my stash and had 2 mopar performance ones that I bought 30 years ago. N beer ow I only have one bawling
Page 3 of 3 1 2 3
