Best way to roll fender lip without cracking paint?.... #66003
05/30/08 12:04 AM
05/30/08 12:04 AM
Castle Rock, CO
pwr440 Offline OP
pwr440  Offline OP
Castle Rock, CO
I'm thinking about taking a cutoff wheel and making cuts and then bending the sections up. Does this sound like it will work?thanks.
britt
Re: Best way to roll fender lip without cracking paint?.... [Re: pwr440] #66004
05/30/08 12:08 AM
05/30/08 12:08 AM
Eastern North Carolina
cyphre666 Offline
cyphre666  Offline
I don't think your paint is going to bend.
The only suggestion I can make would be to use a heat gun and get the paint really warm.
I still don't think it will work though.
Re: Best way to roll fender lip without cracking paint?.... [Re: cyphre666] #66005
05/30/08 12:14 AM
05/30/08 12:14 AM
Castle Rock, CO
pwr440 Offline OP
pwr440  Offline OP
Castle Rock, CO
I didn't think it would work. thanks any way
britt
Re: Best way to roll fender lip without cracking paint? [Re: pwr440] #66006
05/30/08 12:50 AM
05/30/08 12:50 AM
Btween a rock and a hard place
moparlulu Offline
moparlulu  Offline
We used a baseball bat! Put it between the tire and fender started at the front and slowly backed the car up letting the bat roll with the tire. We started with the bat in about the middle and it worked really nice for us.
Re: Best way to roll fender lip without cracking paint?.... [Re: pwr440] #66007
05/30/08 02:03 AM
05/30/08 02:03 AM
Orange County, CA
Jolly_Raj_R Offline
Jolly_Raj_R  Offline
Orange County, CA
I agree with the baseball bat routine above.. Cut-off wheel and bending it up in sections opens you up to lots of areas for rust to settle in.. Besides, you shouldn't need to cut good sheetmetal unless its an absolutely necessary thing.. Grab a good, beat-up wooden baseball bat and go to town..
Re: Best way to roll fender lip without cracking paint?.... [Re: Jolly_Raj_R] #66008
05/30/08 02:13 AM
05/30/08 02:13 AM
Sorrento, BC, Canada
4speeds4me Offline
4speeds4me  Offline
2 Demons...no, not my kids!
Re: Best way to roll fender lip without cracking paint?.... [Re: 4speeds4me] #66009
05/30/08 08:14 AM
05/30/08 08:14 AM
Castle Rock, CO
pwr440 Offline OP
pwr440  Offline OP
Castle Rock, CO
Thanks, although I'll probably be too scared to try it. My car is not a show car but it looks pretty good.
britt
Re: Best way to roll fender lip without cracking paint?.... [Re: pwr440] #66010
05/30/08 10:04 AM
05/30/08 10:04 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
STOP!!
If you're doing that on the black car, you're wasting your time.
The wheel house is usually what contacts the tire in these cars. Look inside the quarter and you'll see the rounded inner fender. It's much narrower than the wheel opening. When the suspension compresses the tire rides up into the wheel well and rubs the outer portion of the wheel house.
The outside bodywork has nothing to do with it.
Take the wheel off and use a mid-sized dead blow hammer to massage the wheel house. Don't whack it too hard.
If yours has already been modified, I'll sit down and shut up.
- Stu Harmon
Re: Best way to roll fender lip without cracking paint?.... [Re: feets] #66011
05/30/08 11:19 AM
05/30/08 11:19 AM
New Mexico
UCUDANT Online content
Troll Hunter
UCUDANT  Online Content
Troll Hunter
New Mexico
That car is sweet, I would not modify the wheel lip. I have seen warped qtr panels and long faces after such an act.
Taking a baseball bat to your car.... PLEASE re-read that again carefully. Taking a baseball bat to your car.
I would highly suggest you use a tool that allows a controlled result. These cars did not live this long for us to take a short cut that could be very risky. I opted to relocte springs and use custom backspace etc in my Cuda.
Looks like you have about a 295 under there now what is the reason you are wanting to do this? Do they rub?
Re: Best way to roll fender lip without cracking paint?.... [Re: UCUDANT] #66012
05/30/08 12:01 PM
05/30/08 12:01 PM
Wow, that's a nice lookin' 64.
Re: Best way to roll fender lip without cracking paint?.... #66013
05/30/08 02:08 PM
05/30/08 02:08 PM
Castle Rock, CO
pwr440 Offline OP
pwr440  Offline OP
Castle Rock, CO
Thanks gy3. The springs are moved inboard. In the pic the rear tires are 325-50's on 11 inch rims. When I had them widened I didn't move the wheel center and it left me with alot of backspace (costly mistake). Any way, I was able to use a 1 inch spacer but I don't like using a spacer. They did rub a little on the inside if I went over a bump or railroad tracks. I'm in the process of getting another set widened and was basically trying to get every little bit of room I can. Feets, I know wahat you mean about the wheelhouse I noticed it yesterday when I was measuring stuff.
britt
Re: Best way to roll fender lip without cracking paint?.... [Re: pwr440] #66014
05/30/08 04:15 PM
05/30/08 04:15 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here is what I do and it works good on nice cars as long as you take your time and dont slip. I take a cutter wheel in my air wizzer and I cut a slot very carefully in the lip as I cut from inside and cut the 1/2" or so to to the fender. I make a cut about every 1 inch. The I take a pair of pliers and grab a 1 inch section at a time and slowly bend it up. Then when it close as you cant get it flush with the pliers on it I take the butt end of a hammer handle and push on it very slowly and it pushes the metal flat against the inner 1/4 fenderwell. I never hit the 1/4 I just push on it to get it all the way flush. I have done this many times and it works good. You just need to take your time and by no means rush it. Ron
Re: Best way to roll fender lip without cracking paint?.... [Re: 383man] #66015
05/30/08 05:33 PM
05/30/08 05:33 PM
Castle Rock, CO
pwr440 Offline OP
pwr440  Offline OP
Castle Rock, CO
Thanks for the tips Ron (and every body else). Ron, that pic with the front wheel cheating gravity is bad.
britt
Re: Best way to roll fender lip without cracking paint?.... [Re: pwr440] #66016
05/30/08 08:24 PM
05/30/08 08:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thank you. Ron
