K member Question 70' B-body into 71' E-body #660021
04/03/10 05:31 PM
04/03/10 05:31 PM
PORT ALBERNI B.C. CANADA
71DemonRON Offline OP
My challenger needs a replacement k member, I have a chance to pick up a 70' B-body K member with a factory skid plate. I know it will bolt in, but I have heard the mounting for the steering box is at a different angle than an E-body. Is this true ? I will be running a 440 at first , then a HEMI later on. THANKS for your help
1971 Demon drag car
2004 SX 2.0
1971 Duster 340 4 speed , project for my Daughter
1998 Dodge Ram 3500 SLT Laramie quad cab dually 4x4 V10
Re: K member Question 70' B-body into 71' E-body [Re: 71DemonRON] #660022
04/03/10 05:48 PM
04/03/10 05:48 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IIRC the sway bar mounts differently. and a HEMI X member is different too.
I am truckless..
Re: K member Question 70' B-body into 71' E-body [Re: 340SHORTY] #660023
04/03/10 05:55 PM
04/03/10 05:55 PM
I thought that the 1969 and back had the sway bar mounted up front on the K member and the 1970 & up had the sway bar passing through the front of the k member. I will use the Schumacher coversion mounts when I do the HEMI swap.
1971 Demon drag car
2004 SX 2.0
Re: K member Question 70' B-body into 71' E-body [Re: 71DemonRON] #660024
04/03/10 08:46 PM
04/03/10 08:46 PM
I am most concerned with the angle of the steering box mount, IF it is different ?
1971 Demon drag car
2004 SX 2.0
Re: K member Question 70' B-body into 71' E-body [Re: 71DemonRON] #660025
04/04/10 12:23 AM
04/04/10 12:23 AM
I found an old post by Dr. Diff, I need to find a E-body or 1971-72 B-body K member due to the steering box angle.
1971 Demon drag car
2004 SX 2.0
Re: K member Question 70' B-body into 71' E-body [Re: 71DemonRON] #660026
04/04/10 12:44 AM
04/04/10 12:44 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yeah the angle is different, but I've done the swap years ago with no adverse affect... The coupler is able to flex more than enough to compensate..
And 70 B & E sway bars use the same design mounting...
Hemi engine mounting is different but you can mount to a 440 K member with Schmacher brackets...
Re: K member Question 70' B-body into 71' E-body [Re: 1_WILD_RT] #660027
04/04/10 10:31 AM
04/04/10 10:31 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
There is a 3 degree difference in the angle of the steering box,and that is the only difference. The B-body k frame will tilt the box at more upward angle. The sway bar and mounts are the exact same thing on 70 E and B bodies. If you don't tell anybody,they won't know the difference. If you are worried about the steering coupler,use a Flaming River coupler with a u joint in it.
Re: K member Question 70' B-body into 71' E-body [Re: JDMopar] #660028
04/04/10 12:04 PM
04/04/10 12:04 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
just between 70/72 B and all E... up to 69 Bs are slightly diff on the sway bar attaching deal... since 73 B is TOTALLY diff
Now,wondering, if we got 3º diff, what about pitman arm ?
Re: K member Question 70' B-body into 71' E-body [Re: JDMopar] #660029
04/04/10 02:00 PM
04/04/10 02:00 PM
I found this pic in another old post. It is a 1970 E-body k member in a 1969 B-body. It looks like a side to side difference too. The steering shaft should be in-line with the steering box.
1971 Demon drag car
2004 SX 2.0
Re: K member Question 70' B-body into 71' E-body [Re: 71DemonRON] #660030
04/04/10 02:07 PM
04/04/10 02:07 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
mmm, dunno... suposelly the front frame is the same between both. In fact the B body was the plattform to build the E body and fit bigger engines on a Pony car category
