Re: K member Question 70' B-body into 71' E-body
[Re: 71DemonRON]
#660022
04/03/10 05:48 PM
04/03/10 05:48 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
IIRC the sway bar mounts differently. and a HEMI X member is different too.
I am truckless..
[Re: 71DemonRON]
#660024
04/03/10 08:46 PM
04/03/10 08:46 PM
Posts: 484 PORT ALBERNI B.C. CANADA
71DemonRON
I am most concerned with the angle of the steering box mount, IF it is different ?
1971 Demon drag car
2004 SX 2.0
1971 Duster 340 4 speed , project for my Daughter 1998 Dodge Ram 3500 SLT Laramie quad cab dually 4x4 V10
[Re: 71DemonRON]
#660026
04/04/10 12:44 AM
04/04/10 12:44 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
I found an old post by Dr. Diff, I need to find a E-body or 1971-72 B-body K member due to the steering box angle.
Yeah the angle is different, but I've done the swap years ago with no adverse affect... The coupler is able to flex more than enough to compensate.. And 70 B & E sway bars use the same design mounting... Hemi engine mounting is different but you can mount to a 440 K member with Schmacher brackets...
[Re: JDMopar]
#660029
04/04/10 02:00 PM
04/04/10 02:00 PM
71DemonRON
I found this pic in another old post. It is a 1970 E-body k member in a 1969 B-body. It looks like a side to side difference too. The steering shaft should be in-line with the steering box.
1971 Demon drag car
2004 SX 2.0
[Re: 71DemonRON]
#660030
04/04/10 02:07 PM
04/04/10 02:07 PM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
mmm, dunno... suposelly the front frame is the same between both. In fact the B body was the plattform to build the E body and fit bigger engines on a Pony car category
