Re: Home Porting W2 heads help
[Re: The Shocker]
#659344
04/02/10 08:36 PM
04/02/10 08:36 PM
Posts: 1,532 off the grid
340B5
off the grid
They say stay away from the short-turn if you're not a pro. There are some good posts here on the subject by OU812 and S/ST3040.(others too) Spend some time doing searches: it should pay off.
Yeah, it's got a smallblock.
[Re: 340B5]
#659345
04/02/10 08:45 PM
04/02/10 08:45 PM
Posts: 429 Sherman Texas
The Shocker
Sherman Texas
Thanks , i will check out the posts ...
[Re: Cyl.Porter]
#659349
04/02/10 09:10 PM
04/02/10 09:10 PM
The Shocker
Sherman Texas
hello. my name is jason schagt. i own shottie`s porting service. if you need any help or have questions please feel free and give me a call @ 1-712-790-6106 anytime. i`ve done a few sets of W2`s. more bbc factory iron and edelbrocks. hope to hear from you.
Thanks ,and expect to hear from me.I am going to run it in a Nostalgia race in early May as is.When i get home im gunna start tearing it down.I know i will have a few questions to ask as im porting them.Thanks again for the offer freind ...
[Re: The Shocker]
#659350
04/02/10 11:32 PM
04/02/10 11:32 PM
Posts: 3,504 DFW
mr_340
DFW
I had Jeff do a set for me. Maybe these photos will help, maybe not? Intakes.
Floyd Lippencott IV
[Re: mr_340]
#659351
04/02/10 11:34 PM
04/02/10 11:34 PM
Posts: 3,504 DFW
mr_340
DFW
The intakes flowed around 320 cfm @ .700" if I remember right. I think RyanJs flowed close to these. Here is an exhaust pic.
Floyd Lippencott IV
[Re: mr_340]
#659352
04/03/10 12:53 AM
04/03/10 12:53 AM
Posts: 5,485 SoCal
Brian Hafliger
SoCal
There might be some air in the chamber and valve job...
Brian Hafliger
[Re: Cyl.Porter]
#659354
04/03/10 06:51 AM
04/03/10 06:51 AM
The Shocker
Sherman Texas
yes there is more air flow and power in a properly shaped chamber and design and shapes of angles cut into the seats. if you have the chambers and the intake runners to smooth air flow will in a gas powered motor, because the air and fuel seperate and the fuel begins to puddle. a way to tell if you intake manifold is shaped and texture is make a pass or dyno the engine and pull the carb off the manifold and look inside to see if there is fuel stains on the plenum floor. if is the the manifold isn`t ported right and it`s way to smooth. the fuel stain shld be in the roof of the manifold right were the carb pad and runner begins. this is for wedge type motors, there high pressure area is in the roof, but a hemi`s high pressure is in the floor. thats because of the segin of the chamber. what im tryin to say is that dont take a 120 grit sand paper roll to the intake runners or chamber. that is way to smooth for a gas powered car. use a 60 grit roll. if it was a deisel then use 180 on the intake, the fuel is added after the valve. i hope this helped you.
Thats exactly the kind of info im after right there.I always thought that a "glass" type finish was ideal ,but i guess not.So finish out with a 60 grit roll ,got it ...
