Re: Need Tech Help - Brakes
[Re: Todd]
#658538
04/01/10 11:04 PM
04/01/10 11:04 PM
RapidRobert
Take off the lines from the master and plug the master w several dollars worth of (2)brass plugs and if the M/C is good and bled out the pedal will be rock hard w virtually no travel. Not familiar w ABS. If good hookup the front discs and bleed them out.
[Re: NJK66]
#658539
04/01/10 11:11 PM
04/01/10 11:11 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
I have a 1997 Dodge Stratus that was given to me. It has 50,000 miles but has been sitting for 4 years. The brake pads were frozen to the calipers so I decided to be safe and replaced everything front and rear.
1) Front - Rotors, calipers, brake pads 2) Rear - Drums, brake shoes, hardware kit, left and right rubber brake lines, right and left wheel cylinders 3) Master cylinder.
My problem is I cannot get a brake pedal. I have bled the heck out of them and still no pedal. The rear brakes are adjusted properly. Am I missing something??
Any advice would be a great help.
what order are you bleeding? I think that system is diagonally split. If so, you need to bleed LR, RF, RR then LF instead of the usual RR,LR,RF,LF.
