Need Tech Help - Brakes #658533
04/01/10 10:12 PM
04/01/10 10:12 PM
N
NJK66 Offline OP
super street
NJK66  Offline OP
super street
N
I have a 1997 Dodge Stratus that was given to me. It has 50,000 miles but has been sitting for 4 years. The brake pads were frozen to the calipers so I decided to be safe and replaced everything front and rear.
1) Front - Rotors, calipers, brake pads
2) Rear - Drums, brake shoes, hardware kit, left and right rubber brake lines, right and left wheel cylinders
3) Master cylinder.
My problem is I cannot get a brake pedal. I have bled the heck out of them and still no pedal.
The rear brakes are adjusted properly. Am I missing something??
Any advice would be a great help.
Re: Need Tech Help - Brakes [Re: NJK66] #658534
04/01/10 10:27 PM
04/01/10 10:27 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Unbolt the master cylinder and make sure the piston is coming all the way back against the retainer. May have some corrosion at the end of the piston bore.
Re: Need Tech Help - Brakes [Re: Todd] #658535
04/01/10 10:34 PM
04/01/10 10:34 PM
N
NJK66 Offline OP
super street
NJK66  Offline OP
super street
N
Are you saying corrosion in the back of the Master Cylinder? If you are the M/C is a rebuilt unit. So it is clean as a pin. Or do you mean at the vacuum booster interface?
Re: Need Tech Help - Brakes [Re: NJK66] #658536
04/01/10 10:42 PM
04/01/10 10:42 PM
IN
ahy Offline
ahy  Offline
IN
The pistons need to extend enough to take up the clearance used when the new pads/calipars were installed. It make take some pumping to take it up. How long have you "pumped"?
Also, if the MC was new/rebuilt, did you "bench bleed"?
Re: Need Tech Help - Brakes [Re: NJK66] #658537
04/01/10 10:44 PM
04/01/10 10:44 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Sorry my mistake. I didn't see that you replaced the master. Does the car have abs?
Re: Need Tech Help - Brakes [Re: Todd] #658538
04/01/10 11:04 PM
04/01/10 11:04 PM
Take off the lines from the master and plug the master w several dollars worth of (2)brass plugs and if the M/C is good and bled out the pedal will be rock hard w virtually no travel. Not familiar w ABS. If good hookup the front discs and bleed them out.
Re: Need Tech Help - Brakes [Re: NJK66] #658539
04/01/10 11:11 PM
04/01/10 11:11 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
3) Master cylinder.
what order are you bleeding? I think that system is diagonally split. If so, you need to bleed LR, RF, RR then LF instead of the usual RR,LR,RF,LF.
Re: Need Tech Help - Brakes [Re: 446acuda] #658540
04/02/10 09:49 AM
04/02/10 09:49 AM
Northern VA
1970440six Offline
1970440six  Offline
Northern VA
Did you bleed the master cylinder before installing it on the car? Or at least before you connected the brake lines? If not you will have a hard time bleeding.
Re: Need Tech Help - Brakes [Re: 1970440six] #658541
04/02/10 10:50 AM
04/02/10 10:50 AM
N
NJK66 Offline OP
super street
NJK66  Offline OP
super street
N
Master Cylinder was bench bled and then I cracked the lines to get any air that may have been left in the M/C during installation. The car does not have ABS. I bled the M/C first then the RR LR RF LF. I have been wrenching on cars for a long time and I have never encountered a bleeding problem like this. I probably have been bleeding 4 times the normal time to bleed a set of brakes. I remember an 1984 Dodge mini-van rears was a toughie but it eventually bled. I will try pluggind up the M/C. Potentially bad because it is a rebuild.
Re: Need Tech Help - Brakes [Re: NJK66] #658542
04/03/10 09:10 PM
04/03/10 09:10 PM
N
NJK66 Offline OP
super street
NJK66  Offline OP
super street
N
Found the problem. The right and left side calipers are different. My error was I put them on the wrong side and the bleeder screw was sitting in a position where air was trapped in the top of the caliper. So, I could have bled til doomsday and never got any pedal. Switch calipers side to side and the bleeder was an inch higher and no air was trapped in the top. They bled out perfect and now have a nice firm pedal. Thanks to all who replied.
Re: Need Tech Help - Brakes [Re: NJK66] #658543
04/03/10 10:43 PM
04/03/10 10:43 PM
Glad ya got it as that sure could fool a person cause most bleeder screws are not exactly at 12 0'clock and dont need to be but where the bleeder passage meets the bore like a passage in the pyramids needs to be at 12 0'clock so all the air can get out like the hole in the plexiglass plate when you're CC ing the heads needs to be at the top and I am wondering how the calipers are ID'd for location with the bleeders being so close. It's not like a bleeder screw was on the bottom
