Promax center carb metering block #658340
04/01/10 05:17 PM
04/01/10 05:17 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
Anyone used it on their center six pak.What type of different did it make?
Re: Promax center carb metering block [Re: gtx69] #658341
04/01/10 06:54 PM
04/01/10 06:54 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I don't know about all that, but I have one on my sixpack and it runs great!
Re: Promax center carb metering block [Re: jbc426] #658342
04/01/10 07:01 PM
04/01/10 07:01 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
Since I've installed one on my car, I noticed that I don't have to screw around with it as much as before. You might want to get the adjustable plates for the outboards and the billet base for the rear carb.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Promax center carb metering block [Re: 70sixpkrt] #658343
04/01/10 07:10 PM
04/01/10 07:10 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
I already have the base and the plates
Re: Promax center carb metering block [Re: 70sixpkrt] #658344
04/02/10 09:29 PM
04/02/10 09:29 PM
Queens, N. Y.
FASTBACK340 Offline
FASTBACK340  Offline
Queens, N. Y.
I agree. My car runs great with no bogging or eractic idle issues.
I also installed the jet-able end carb metering plates....
...and the modified rear carb base plate.
I still have some fine tuning when I have the time, but for the most part it was money well spent. I started with a set of re-production Holleys and they've been great.
I also couldn't resist Promax's braided fuel line too.... It's all good.
`68 Barracuda 340-S
Re: Promax center carb metering block [Re: FASTBACK340] #658345
04/06/10 03:05 PM
04/06/10 03:05 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
I order my promax metering block today.Have anyone changed there power valve mine is a 6.5. Going to check vaccum and see where i'm at.
Re: Promax center carb metering block [Re: gtx69] #658346
04/06/10 03:06 PM
04/06/10 03:06 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
other side
Re: Promax center carb metering block [Re: gtx69] #658347
04/06/10 03:53 PM
04/06/10 03:53 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
That's a wild looking set-up!! I'm pulling single digit vacuum numbers at idle and ended up with a 3.5 PV in the present tuning.... In addition to the usual mods I also snagged the Promax fuel bowls with the sight glass for easier tuning...I tried every brand of clear sight plugs out there but they just are'nt designed to be left in the bowl for any length of time...
Re: Promax center carb metering block [Re: screamindriver] #658348
04/06/10 04:17 PM
04/06/10 04:17 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
Where is the best place to check for vaccum?I have everything from promax.Trying to get everything in the ball park.Then going to have it tuned on a chassis dyno.
Re: Promax center carb metering block [Re: gtx69] #658349
04/06/10 10:00 PM
04/06/10 10:00 PM
70sixpkrt Offline
70sixpkrt  Offline
I have a vacuum gauge hooked up to the vacuum port behind the manifold. I am reading 14" of vacuum and using a 6.5 power valve. I talked to Mr. Sixpack(Bob K.) and he said I could bring it down to a 4.5 power valve.
4-speed
3:54 Dana
Re: Promax center carb metering block [Re: 70sixpkrt] #658350
04/06/10 10:40 PM
04/06/10 10:40 PM
gtx69 Offline OP
super gas
gtx69  Offline OP
super gas
My manfold dosen't have any ports.
