Mount electric fuel pump inline with mechanical pump? #658312
04/01/10 05:13 PM
04/01/10 05:13 PM
Wichita,KS
Blakcharger440 Offline OP
Wichita,KS
I plan on installing a Holley blue pump in line with my mechanical fuel pump. I will be using the elecric fuel pump mainly for initial start purposes as my fuel seems to drain back within a day so my 70 Charger RT is always hard to start after sitting for awhile.
Would this cause any problems?
Please no comments about Holley fuel pumps being loud....it wont be running all the time and I wouldnt be able to hear it anyways over my exhaust noise.
Re: Mount electric fuel pump inline with mechanical pum [Re: Blakcharger440] #658313
04/01/10 05:38 PM
04/01/10 05:38 PM
I ran a Holley Blue near the tank with a toggle--had a Carter Mechanical up front on a 550 HP 451--ran on mechanical most times but it would lay over when I really got into it --so-flip on the electric when I was ready to make a pass or jump on a Ford at the light and bam! NO problems--actually picked my 1/4 mile time up a ton--I did have a Holley regulator near the carb--It works but you HAVE to have a vent on the tank or a small hole in the gas cap with the electric
Re: Mount electric fuel pump inline with mechanical pum [Re: ] #658314
04/01/10 06:59 PM
04/01/10 06:59 PM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
Don't they make 1 way valves for fuel? I have a 5/16" one way valve that a guy here was manufacturing. Its not on my car but I tested it and it works....He told me that it was a standard option valve on some Mercedes Benz in the 90s. Maybe look into that? I have no problem with drainback so I dunno what to tell you
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Mount electric fuel pump inline with mechanical pum [Re: Pyper70] #658315
04/01/10 07:04 PM
04/01/10 07:04 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
You should run one or the other. Not both. You're hard start isnt drainback, it's the fuel evaporating faster tahn any fuel used to. So your carb goes dry and you need to turn the engine to fill the carb again. The mechanical isnt real good at suction. So it wont pull well thru the electric. The electric wont pump thru the mechanical very well. So, I'd say you can know ahead you have to turn it over for 10 seconds, then pump the gass twice and fire it... Or, remove the pump and install the Holley pump with a proper relay and wiring, and the regulator the blue pump needs, and just running that. Also, if it's noise you might be concerned about (the comment about not running it all the time) I would say use the Carter electric that requires no regulator and is about 1/2 the noise.
Re: Mount electric fuel pump inline with mechanical pum [Re: Pyper70] #658316
04/01/10 07:05 PM
04/01/10 07:05 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I'm in the same situation. I bought a Carter elect. pump but have not installed it yet.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Mount electric fuel pump inline with mechanical pum [Re: moper] #658317
04/01/10 07:13 PM
04/01/10 07:13 PM
Greer, SC
TooMany62s Online content
TooMany62s  Online Content
Greer, SC
Why not both? I've been running two for a couple of years. No problems.
Re: Mount electric fuel pump inline with mechanical pum [Re: TooMany62s] #658318
04/01/10 07:20 PM
04/01/10 07:20 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
MP has recommended running an electric in series with a mechanical for over 30 years. I have always run this setup on my street cars, using the Carter electrics because they are more reliable and quieter than the Holleys. I am running this combo on my 528 Hemi and it works just fine. No reason not to run it, but you will need a regulator.
Re: Mount electric fuel pump inline with mechanical pum [Re: Lee446] #658319
04/01/10 07:43 PM
04/01/10 07:43 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
install the pump in paralell in the system. that way the mech pump doesnt work so hard tring to suck through the elec pump when its off..
I am truckless..
Re: Mount electric fuel pump inline with mechanical pump? [Re: Blakcharger440] #658320
04/01/10 07:43 PM
04/01/10 07:43 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
For years i ran the factory mech pump with a Holley Blue in the back. Best of both worlds IMO. Drove on just the factory pump most of the time. All the wear and tear of daily driving on the cheap(free, it was already there) factory pump while greatly extending the life of the more expensive electric pump. I just flipped the electric on when racing or to fill the carb bowls after having sat awhile. It's also nice to be able to check for fuel leaks after doing any carb or fuel system work before starting the engine. Also you don't have to worry about being stranded far from home due to a faulty fuel pump, you have an extra one already installed
Re: Mount electric fuel pump inline with mechanical pump? [Re: Blakcharger440] #658321
04/01/10 07:47 PM
04/01/10 07:47 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
When installing one of the popular electric pumps you'll have to run it all the time because they won't allow the mechanical pump to pull through the electric.
To use the electric pump only for refilling the carbs you'll need an elaborate system of check valves or find a pump that allows pull-through. (piston aircraft have them)
Re: Mount electric fuel pump inline with mechanical pump? [Re: John_Kunkel] #658322
04/01/10 07:51 PM
04/01/10 07:51 PM
70sixpkrt Offline
70sixpkrt  Offline
Hmm, I never thought of that.
4-speed
3:54 Dana
Re: Mount electric fuel pump inline with mechanical pum [Re: 340SHORTY] #658323
04/01/10 07:55 PM
04/01/10 07:55 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Running them in parallel might be a good idea, but i ran mine in series and it worked fine. Had that setup for about 10 years in a car that was pretty much a daily driver. Decided i wanted to ditch my 5/16 line and go with 1/2, along with a fuel cell. Eliminated the stock pump and just ran the Holley electic. Found out that a Holley blue doesn't seem to last very long in constant useage.
Re: Mount electric fuel pump inline with mechanical pump? [Re: John_Kunkel] #658324
04/01/10 08:01 PM
04/01/10 08:01 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I don't know what you mean by "popular electric pumps", but my stock pump pulled through my Holley blue just fine. And the Holley pushed through the mechanical pump with the engine off.
Re: Mount electric fuel pump inline with mechanical pump? [Re: John_Kunkel] #658325
04/01/10 08:14 PM
04/01/10 08:14 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
That's how I understand it too.
Re: Mount electric fuel pump inline with mechanical pump? [Re: moper] #658326
04/01/10 08:28 PM
04/01/10 08:28 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Never had any problems with the mech pulling through the electric... ever. If you have any power, you will have to run the electric for max power runs.
Re: Mount electric fuel pump inline with mechanical pum [Re: Lee446] #658327
04/01/10 09:14 PM
04/01/10 09:14 PM
We have done it--and it works--scrap any other theories--it works just great--I also like the Carter electrics--they are trouble free. I had a good runner that would run a 10.90 easy--added the electric and went 10.68 first pass--seen similar with many "good running" cars
Re: Mount electric fuel pump inline with mechanical pum [Re: ] #658328
04/01/10 09:27 PM
04/01/10 09:27 PM
P
Paul_Fancsali Offline
P
After years of only going to track on days it was below 80I'm pleased to say I have run mech and electric combined on 4 cars for over 20 years I have found stock mech pumps from even late 80s 360's work well with the electric as does the high perf Carter. Today was in the 80s and I run a 195 stat and the car performs great.
Re: Mount electric fuel pump inline with mechanical pum [Re: Paul_Fancsali] #658329
04/02/10 01:50 AM
04/02/10 01:50 AM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
I have the same situation with my Hemi Road Runner carbs going dry after a week or so and I hate having to manually prime the carbs. This topic has come up a few times before and it was mentioned that the Carter P4602RV pump would allow fuel pull through flow when the pump was off. The Carter website is a bit vague about this feature. The P4602RV, and P4070 both have the smaller 1/4 fittings. The P4600HP has the larger 3/8 fittings with an 8PSI rating. Does anyone have real world experience with any of those Carter models and their ability to allow the existing mechanical pump to pull through during normal use once the engine is started and power is turned off to the electric pump.
Re: Mount electric fuel pump inline with mechanical pum [Re: moper] #658330
04/02/10 02:06 AM
04/02/10 02:06 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Run a single decent electric pump and call it a day. OEM has been running electric pumps for 30 years. The dual system works, but seems like useless redundancy to me. I guess it's just because I always forsee the mech pump not being able to suck through the elec pump, or at a reduced fuel volume. Or the elec pump not being able to fully flow through the mech pump. But then my preferred setup is to run an electric pump with a return line and a return style regulator to ensure a constant, regulated and cool fuel flow.
Re: Mount electric fuel pump inline with mechanical pum [Re: DaytonaTurbo] #658331
04/03/10 09:23 AM
04/03/10 09:23 AM
Virginia
JimG Offline
JimG  Offline
Virginia
Also consider the fact that if the mechanical pump's diaphragm ruptures, the electric pump can fill your crankcase with gasoline. Not good.
Yeah, I know, there are people who've run this setup for [insert time period here] with no problems, so it can be done successfully. But my luck is traditionally not good enough to dodge this bullet, so my advice is to avoid it.
To paraphrase Dirty Harry: Do you feel lucky?
