Re: Mount electric fuel pump inline with mechanical pum
[Re: Blakcharger440]
#658313
04/01/10 05:38 PM
04/01/10 05:38 PM
I ran a Holley Blue near the tank with a toggle--had a Carter Mechanical up front on a 550 HP 451--ran on mechanical most times but it would lay over when I really got into it --so-flip on the electric when I was ready to make a pass or jump on a Ford at the light and bam! NO problems--actually picked my 1/4 mile time up a ton--I did have a Holley regulator near the carb--It works but you HAVE to have a vent on the tank or a small hole in the gas cap with the electric
[Re: ]
#658314
04/01/10 06:59 PM
04/01/10 06:59 PM
Posts: 5,907 Athens, Greece
Pyper70
Athens, Greece
Don't they make 1 way valves for fuel? I have a 5/16" one way valve that a guy here was manufacturing. Its not on my car but I tested it and it works....He told me that it was a standard option valve on some Mercedes Benz in the 90s. Maybe look into that? I have no problem with drainback so I dunno what to tell you
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
[Re: Pyper70]
#658315
04/01/10 07:04 PM
04/01/10 07:04 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
You should run one or the other. Not both. You're hard start isnt drainback, it's the fuel evaporating faster tahn any fuel used to. So your carb goes dry and you need to turn the engine to fill the carb again. The mechanical isnt real good at suction. So it wont pull well thru the electric. The electric wont pump thru the mechanical very well. So, I'd say you can know ahead you have to turn it over for 10 seconds, then pump the gass twice and fire it... Or, remove the pump and install the Holley pump with a proper relay and wiring, and the regulator the blue pump needs, and just running that. Also, if it's noise you might be concerned about (the comment about not running it all the time) I would say use the Carter electric that requires no regulator and is about 1/2 the noise.
[Re: moper]
#658317
04/01/10 07:13 PM
04/01/10 07:13 PM
Posts: 1,796 Greer, SC
TooMany62s
Greer, SC
Why not both? I've been running two for a couple of years. No problems.
[Re: Lee446]
#658319
04/01/10 07:43 PM
04/01/10 07:43 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
install the pump in paralell in the system. that way the mech pump doesnt work so hard tring to suck through the elec pump when its off..
I am truckless..
Re: Mount electric fuel pump inline with mechanical pump?
#658321
04/01/10 07:47 PM
04/01/10 07:47 PM
Posts: 25,982 Rio Linda, CA
John_Kunkel
Rio Linda, CA
When installing one of the popular electric pumps you'll have to run it all the time because they won't allow the mechanical pump to pull through the electric.
To use the electric pump only for refilling the carbs you'll need an elaborate system of check valves or find a pump that allows pull-through. (piston aircraft have them)
[Re: John_Kunkel]
#658322
04/01/10 07:51 PM
04/01/10 07:51 PM
Posts: 3,685 South San Francisco, Ca
70sixpkrt
Hmm, I never thought of that.
[Re: 340SHORTY]
#658323
04/01/10 07:55 PM
04/01/10 07:55 PM
Posts: 1,460 oklahoma
forphorty
oklahoma
Running them in parallel might be a good idea, but i ran mine in series and it worked fine. Had that setup for about 10 years in a car that was pretty much a daily driver. Decided i wanted to ditch my 5/16 line and go with 1/2, along with a fuel cell. Eliminated the stock pump and just ran the Holley electic. Found out that a Holley blue doesn't seem to last very long in constant useage.
[Re: John_Kunkel]
#658324
04/01/10 08:01 PM
04/01/10 08:01 PM
forphorty
oklahoma
I don't know what you mean by "popular electric pumps", but my stock pump pulled through my Holley blue just fine. And the Holley pushed through the mechanical pump with the engine off.
[Re: moper]
#658330
04/02/10 02:06 AM
04/02/10 02:06 AM
DaytonaTurbo
Manitoba, Canada
Run a single decent electric pump and call it a day. OEM has been running electric pumps for 30 years. The dual system works, but seems like useless redundancy to me. I guess it's just because I always forsee the mech pump not being able to suck through the elec pump, or at a reduced fuel volume. Or the elec pump not being able to fully flow through the mech pump. But then my preferred setup is to run an electric pump with a return line and a return style regulator to ensure a constant, regulated and cool fuel flow.
[Re: DaytonaTurbo]
#658331
04/03/10 09:23 AM
04/03/10 09:23 AM
Posts: 531 Virginia
JimG
Virginia
Also consider the fact that if the mechanical pump's diaphragm ruptures, the electric pump can fill your crankcase with gasoline. Not good. Yeah, I know, there are people who've run this setup for [insert time period here] with no problems, so it can be done successfully. But my luck is traditionally not good enough to dodge this bullet, so my advice is to avoid it. To paraphrase Dirty Harry: Do you feel lucky?
