Shifting Manual Valve Body - Easier to Push, or Pull? #658020
04/01/10 01:33 PM
04/01/10 01:33 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
Hi guys....will be ordering a PPP shifter for my car (mostly street driven). I'll be running a reverse pattern - and I'm guessing it's a lot easier to the slam the shifter forward (while upshifting) instead of pulling the trigger and handle back? I'm used to my slapstick and assumed forward motion is just easier than pulling back.
However, I noticed in a lot of shifter pics that several race cars pull back to upshift....would seem clumsy to me. Am I missing something, or is it a personal preference thing?
Thanks for any info!!
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: kielbasa] #658021
04/01/10 01:52 PM
04/01/10 01:52 PM
Cab_Burge Online work
Cab_Burge  Online Work
I prefer the reverse pattern valve bodys and shifters, it is pretty hard to go from third to nuetral while shifting back towards the stop in the shifter. I have shifted from 3rd to nuetral in a forward pattern valve body and shifter Also into reverse once I no longer try to shift the the trans into nuetral at the finish line, no matter what One thing bad about the reverse pattern shifters that are not a lever activated or a click type rachet shifter is that if you leave your hand on the shifter and leave hard in 1st gear you can shift it into 2nd on the hit I have the TA, Fairbanks type shifters and love them I have had a driven other cars with a lot of other brands annd types of shifters and I like the TA type best
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: Cab_Burge] #658022
04/01/10 02:40 PM
04/01/10 02:40 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Mine is a Turbo Action Cheetah shifter and Turbo Action reverse pattern manual valve body. Easier to pull than push
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: kielbasa] #658023
04/01/10 02:44 PM
04/01/10 02:44 PM
Calif, USA
V
viperrt Offline
viperrt  Offline
V
Calif, USA
I have a PPP once you are in 1st you only pull the handle back ie; no lever to touch. Pulling is better.
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: viperrt] #658024
04/01/10 03:05 PM
04/01/10 03:05 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
Another advantage to a RVB is low gear is only one click away from neutral....nice when you're pre-staged if you want to clear the throttle one good time before rolling into the second beam to stage. Less to think about is better
WIZE
In Car:
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: Streetwize] #658025
04/01/10 03:23 PM
04/01/10 03:23 PM
Florida STAYcation
dOoC Online penguin-006
The village idiot's idiot
dOoC  Online Penguin-006
Florida STAYcation
I prefer to PUSH .... 'da buttons ...
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: Streetwize] #658026
04/01/10 03:25 PM
04/01/10 03:25 PM
organ
maximum entropy Offline
organ
Another advantage to a RVB is low geatr is only one click away from neutral....nice when you're pre-staged if you want to clear the throttle one good time before rolling into the second beam to stage. Less to think about is better
that's why i went with reverse.
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: maximum entropy] #658027
04/01/10 04:05 PM
04/01/10 04:05 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
I'd rather pull my shifter, but the shiftnoid won't let me!!! dang that thing can bite hard LOL
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: maximum entropy] #658028
04/01/10 04:10 PM
04/01/10 04:10 PM
Near Reading PA USA
pinkduster Offline
pinkduster  Offline
Near Reading PA USA
My Road Runner had a rev pattern manual valvebody and some sort of B&M shifter (with the factory console) when I bought it. I hated every minute of it. You can't shift to neutral from third if you want to coast. The reverse lockout was a pain in the butt. I also had problems with the cable that eventually left me stranded. I took all that stuff out. Had my friend go through my trans after I lost reverse and had him install a forward pattern manual valvebody. Now I'm running all the factory slap stick parts and it works great. Just slap it through the gears like Mother Mopar intended.
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: viperrt] #658029
04/01/10 05:38 PM
04/01/10 05:38 PM
K
kielbasa Offline OP
kielbasa  Offline OP
K
but don't you pull the lever anyways when pulling the entire handle back?
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: kielbasa] #658030
04/01/10 08:53 PM
04/01/10 08:53 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
Well, I don't use a PPP shifter (I have a B&M pro ratchet) but I have a forward manual valve body and so I push up to shift up.
I can't say I've tried a reverse pattern VB, but I do like pushing it up, with this ratchet shifter it's easy to just slam your hand into it and up it goes.
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: Exit1965] #658031
04/01/10 08:59 PM
04/01/10 08:59 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Pull on my PPP
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: kielbasa] #658032
04/01/10 09:11 PM
04/01/10 09:11 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I prefer to pull it... G force is heading in that
direction also... I use a reverse V/B with a Pro-
ratchet... has NEVER missed a shift... I also prefer
to have the cable pulling... if you get the cable
housing to close to the header it will melt the housing
and the interior cable will pop out the side if you
push the cabls... been there before then I changed ... JMO
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: MR_P_BODY] #658033
04/01/10 09:15 PM
04/01/10 09:15 PM
WI.
4Huntin Offline
4Huntin  Offline
WI.
If your making any power you gotta like the reverse manual.
Just keep your hand of the shifter when you go.
Steve
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: 4Huntin] #658034
04/01/10 09:29 PM
04/01/10 09:29 PM
Long Island, NY
Cudafied Offline
Cudafied  Offline
Long Island, NY
My PPP shifter is a pull but I wish I got it as a push....Hands down the best shifter on the market
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: Cudafied] #658035
04/01/10 11:50 PM
04/01/10 11:50 PM
Mopar Lane,Mississippi
67HEMI Offline
67HEMI  Offline
I like the reverse pattern on my Turbo Action Shifter.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction) '69 Chrysler 300 Convertible 375 HP 440 '71 Plymouth Duster 360 W/EFI (Wife's Ride) '12 Ram MegaCab Dually 6.7 Cummins
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: Cudafied] #658036
04/02/10 12:06 AM
04/02/10 12:06 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats defiantly a personal preference... I myself
think they look very cheap(a couple of alum plates
with a few bolts holding it together).... might be
efficient but cheap..... just my opinion
Also do you have to hold the handle to make a shift,
looks like it to me BUT I dont own one.... I know
alot of guys like them
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: MR_P_BODY] #658037
04/02/10 12:36 AM
04/02/10 12:36 AM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I use a Turbo Action Cheeta manual, rev valve body and a B & M Pro Ratchet with a RPM activated air shifter. Don't pull or push.
Brian
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: '72CudaRacer] #658038
04/02/10 07:55 AM
04/02/10 07:55 AM
K
kielbasa Offline OP
kielbasa  Offline OP
K
hmmm, so some of you would rather pull, some would rather push.....pushing just seems so much easier (like I said, probably from being used to my slapstick - both hands on the wheel, when you need the next gear just hit the shifter and hand back on the wheel (i got manual steering)....
but the drwback i found out is that i need a forward exiting cable if i want to push with a reverse manual valve body...maybe i'll just have to try it both ways?
Re: Shifting Manual Valve Body - Easier to Push, or Pull? [Re: kielbasa] #658039
04/02/10 08:02 AM
04/02/10 08:02 AM
Tampa Florida
dc426 Offline
gotta keep'm separated
dc426  Offline
Tampa Florida
I have a PPP that is a "Push" and that's with a RMVB. When I first got it with the car I was skeptical about "pushing". Now I won't have it any other way. I have too many friends that pull and sometimes pull too hard and go 1st to 3rd. It'll never happen with this shifter.
DC
