Re: Shifting Manual Valve Body - Easier to Push, or Pull?
[Re: kielbasa]
#658021
04/01/10 01:52 PM
04/01/10 01:52 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
I prefer the reverse pattern valve bodys and shifters, it is pretty hard to go from third to nuetral while shifting back towards the stop in the shifter. I have shifted from 3rd to nuetral in a forward pattern valve body and shifter Also into reverse once I no longer try to shift the the trans into nuetral at the finish line, no matter what One thing bad about the reverse pattern shifters that are not a lever activated or a click type rachet shifter is that if you leave your hand on the shifter and leave hard in 1st gear you can shift it into 2nd on the hit I have the TA, Fairbanks type shifters and love them I have had a driven other cars with a lot of other brands annd types of shifters and I like the TA type best
[Re: maximum entropy]
#658027
04/01/10 04:05 PM
04/01/10 04:05 PM
Posts: 637 Kokomo,IN
StripeHOG
Kokomo,IN
I'd rather pull my shifter, but the shiftnoid won't let me!!! dang that thing can bite hard LOL
Andrew Brough D372
1969 Dodge Dart GTS
1.43 60'best
6.82 1/8 98mph
"the light came on and I ran out of talent"
[Re: viperrt]
#658029
04/01/10 05:38 PM
04/01/10 05:38 PM
kielbasa
I have a PPP once you are in 1st you only pull the handle back ie; no lever to touch. Pulling is better.
but don't you pull the lever anyways when pulling the entire handle back?
[Re: kielbasa]
#658032
04/01/10 09:11 PM
04/01/10 09:11 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I prefer to pull it... G force is heading in that direction also... I use a reverse V/B with a Pro- ratchet... has NEVER missed a shift... I also prefer to have the cable pulling... if you get the cable housing to close to the header it will melt the housing and the interior cable will pop out the side if you push the cabls... been there before then I changed ... JMO
[Re: 4Huntin]
#658034
04/01/10 09:29 PM
04/01/10 09:29 PM
Posts: 846 Long Island, NY
Cudafied
Long Island, NY
My PPP shifter is a pull but I wish I got it as a push....Hands down the best shifter on the market
[Re: Cudafied]
#658035
04/01/10 11:50 PM
04/01/10 11:50 PM
Posts: 902 Mopar Lane,Mississippi
67HEMI
I like the reverse pattern on my Turbo Action Shifter.
'33 Plymouth 5 Window Coupe Blown Aluminum HEMI w/bolt ons (under construction)
'69 Chrysler 300 Convertible 375 HP 440
'71 Plymouth Duster 360 W/EFI (Wife's Ride)
'12 Ram MegaCab Dually 6.7 Cummins
[Re: Cudafied]
#658036
04/02/10 12:06 AM
04/02/10 12:06 AM
MR_P_BODY
Thats defiantly a personal preference... I myself think they look very cheap(a couple of alum plates with a few bolts holding it together).... might be efficient but cheap..... just my opinion Also do you have to hold the handle to make a shift, looks like it to me BUT I dont own one.... I know alot of guys like them
