Aftermarket auto shfter in stock 68 B-body console? #65767
05/29/08 07:32 PM
05/29/08 07:32 PM
Flint, MI
Gusteve Offline OP
I Love the Unicorn Song!!
Gusteve  Offline OP
Flint, MI
Hey all,
Is there a good aftermarket shifter that will fit in a stock 68 B-Body console?
I'm not worried about a stock look, and I'm really tired of my sloppy stock shifter. This is for a driver - so I don't need a race shifter, just something that I install in the stock location that will work with the stock console plate.
Also - the stock shifter mounting plate seems to be welded to the floor hump. Would I have to remove this? I'd really like something that was a bolt-in option.
Thanks!
Re: Aftermarket auto shfter in stock 68 B-body console? [Re: Gusteve] #65768
05/29/08 07:40 PM
05/29/08 07:40 PM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
I saw recently where somebody is selling a flat Hurst looking shifter that fits the stock console. You can get it with a pistol grip, or use a knob or t handle of your choice. Pretty sure it has a ratchet or slapstick type mechanisim too, and according to them it's entirely a bolt in deal. If mine were an automatic I'd sure be looking at one. Don't cut it up if you can help it...
Re: Aftermarket auto shfter in stock 68 B-body console? [Re: Silverbullet2] #65769
05/29/08 08:20 PM
05/29/08 08:20 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
I remember seeing a kit to convert your shifter to a slap stick, need to find the mag I saw it in. Possibly someone here knows where to get it.
Re: Aftermarket auto shfter in stock 68 B-body console? [Re: Silverbullet2] #65770
05/29/08 09:05 PM
05/29/08 09:05 PM
Flint, MI
Gusteve Offline OP
Gusteve  Offline OP
Flint, MI
That's exactly what I'm looking for. I peruse the Jegs and Summit catelogs, and there's lots of options, but I want something that would bolt into the stock fitting, and work with the stock console.
My wife always says I have unreasonable expectations of stuff that should exist to solve a given problem.
Re: Aftermarket auto shfter in stock 68 B-body console? [Re: rrunner] #65771
05/29/08 09:08 PM
05/29/08 09:08 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
B&M Megashifter in a 65 Coronet 500 console...
Re: Aftermarket auto shfter in stock 68 B-body console? [Re: dodgeram440] #65772
05/30/08 02:01 PM
05/30/08 02:01 PM
Flint, MI
Gusteve Offline OP
Gusteve  Offline OP
Flint, MI
Was that a bolt-up or did you have to fabricate it?
Re: Aftermarket auto shfter in stock 68 B-body console? [Re: Gusteve] #65773
05/30/08 02:09 PM
05/30/08 02:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
good luck , when you find it let us know , i've not seen anything exect the gunslinger handle that replaced the existing top knob
Re: Aftermarket auto shfter in stock 68 B-body console? [Re: Gusteve] #65774
05/30/08 03:46 PM
05/30/08 03:46 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
The original shifter was mounted to the console. I removed the shifter and cut away the mounts, then attached the new shifter to a plate and mounted that to the floor. On the console lid, I opened up the area where the shifter goes, then attached the shifter plate/boot directly to the top. Fit perfect, except that the console top is kind of V-shaped so there was a bit of a gap underneath the plate.
Sorry I don't have any better pics. This was like 15 years ago and the car is long gone now. One of the ones I miss the most....
Re: Aftermarket auto shfter in stock 68 B-body console? [Re: Gusteve] #65775
05/30/08 05:20 PM
05/30/08 05:20 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I'm pretty sure there is nothing that is a bolt in, so fabrication will be necessary. Here's a B&M Quicksilver and mounting plate in my 66 Coronet. I only tack welded it to the floor so it could be put back to stock by future owners.
Re: Aftermarket auto shfter in stock 68 B-body console? [Re: rrunner] #65776
05/30/08 09:11 PM
05/30/08 09:11 PM
Flint, MI
Gusteve Offline OP
Gusteve  Offline OP
Flint, MI
Maybe you meant this: http://www.duncan-motor-sports.com/prod01.htm
I'm not quite sure how this would work, though.
