quitest mufflers #657418
03/31/10 09:26 PM
03/31/10 09:26 PM
pana illinois
bigblock4x4 Offline OP
pana illinois
need some mufflers that will be "streetfriendly"3" if anyone knows of any,they are for a buddy he says flowmasters are too loud
Re: quitest mufflers [Re: bigblock4x4] #657419
03/31/10 09:41 PM
03/31/10 09:41 PM
Dynomax "super turbo" 17769 (3") Walker brand I believe (didn't note the case length) have gotten good reviews here and is what I am going to go with along w an X pipe and resonators of some sort in the rear along side the leafs both for noise reduction.
Re: quitest mufflers [Re: RapidRobert] #657420
03/31/10 10:31 PM
03/31/10 10:31 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Tell you friend to try some little can mufflers in the tailpipes. Magnaflow or similar.
I'm going to guess that he is like me and will hate the drone that most any mufflers will cause. So he will need the can muffs as resonators later anyway. They might cut the sound back to an acceptable level even with the Flowmasters. The sound will change some too as the last mufflers in the system will influence the exhaust sound a bunch.
I want my fair share
Re: quitest mufflers [Re: SomeCarGuy] #657421
03/31/10 11:48 PM
03/31/10 11:48 PM
Woodinville, WA
Viol8r Offline
Viol8r  Offline
Woodinville, WA
Depending on the combo the super turbos with an X pipe won't always be quieter. They may give you some relief at lower rpms but at highway speeds I found them to be much louder than the ultraflows.
Re: quitest mufflers [Re: bigblock4x4] #657422
04/01/10 08:13 AM
04/01/10 08:13 AM
Switzerland, Europe
Swiss_Robert Offline
Switzerland, Europe
My
I have Dynomax Superturbo (but 2,5") at my '65 GTO. I like the design, they are convenient quiet and I have them as "legal" replacement.
The will become louder when the fiberglass material is partially blowed out.
But I found them a reasonable recommendation.
After all these years having a 440 I realized that this means having an attitude... and a budget.
