Crate Engine Transmission Question #656764
03/31/10 07:58 AM
03/31/10 07:58 AM
PA
KGorney Offline OP
KGorney  Offline OP
PA
I have a MP 300HP 360 crate engine I am putting in a 49 Dodge. I know these engines are externally balanced so that has to be taken in to consideration, but do these engines require the use of a lock-up torque converter? Can I bolt up a 70's - early 90's 727 trans to this engine using the right converter without issue?
Anything else I need to consider when fitting a 727 trans to the Magnum crate engine?
Re: Crate Engine Transmission Question [Re: KGorney] #656765
03/31/10 08:22 AM
03/31/10 08:22 AM
Southern Cal
Noblewk Offline
Noblewk  Offline
Southern Cal
the 727 and 904 will work fine. The easiest solution is to buy a B&M flex plate for the Magnum and use a neutral torque converter.
66 Dart GT, 402 11.18:109 Best 63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best 2000 Ram 2005 Durango Hemi.
Re: Crate Engine Transmission Question [Re: KGorney] #656766
03/31/10 08:23 AM
03/31/10 08:23 AM
Bama
BigDawg72 Offline
BigDawg72  Offline
Bama
They do not require a lock up converter. The transmission itself would dictate that. I bought the B&M externally balanced flexplate for the Magnum 360 (LA vs. Magnum makes a difference) so I could run a neutral balance converter. I bought mine from Cope Racing Transmissions (a site sponsor) and the customer service was #1.
Re: Crate Engine Transmission Question [Re: BigDawg72] #656767
03/31/10 09:00 AM
03/31/10 09:00 AM
PA
KGorney Offline OP
KGorney  Offline OP
PA
Thanks for the tips!
Re: Crate Engine Transmission Question [Re: BigDawg72] #656768
03/31/10 09:33 AM
03/31/10 09:33 AM
MI
Blown69 Offline
mopar addict
Blown69  Offline
mopar addict
MI
Yep, B&M 10242
