Edelbrock Performer gaskets and stuff. #656191
03/30/10 07:39 PM
03/30/10 07:39 PM
Lubbock, TX
E
Erics5th Offline OP
UsedtobeSatellite6
Erics5th  Offline OP
UsedtobeSatellite6
E
Lubbock, TX
Will regular old Felpro gaskets be ok to use, or do I need the Edelbrock gaskets? Also, the bypass fitting that goes into the manifold I found at the local dealer wanted $83 dollars for it..will a 3" 3/4" NPT piece of pipe work? Is the heater hose 5/8"? This is replacing the Eddy SP2P manifold on my '84 5th Avenue, 318. Thanks.
Eric
Re: Edelbrock Performer gaskets and stuff. [Re: Erics5th] #656192
03/30/10 07:46 PM
03/30/10 07:46 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
For the fittings.. http://chucker54.stores.yahoo.net/hehonib.html from Mancini..
And Felpro has always worked for me on just the Performers,LD340's,etc
Re: Edelbrock Performer gaskets and stuff. [Re: OzHemi] #656193
03/31/10 05:22 PM
03/31/10 05:22 PM
Lubbock, TX
E
Erics5th Offline OP
UsedtobeSatellite6
Erics5th  Offline OP
UsedtobeSatellite6
E
Lubbock, TX
Thanks Oz
Eric
Re: Edelbrock Performer gaskets and stuff. [Re: Erics5th] #656194
03/31/10 05:33 PM
03/31/10 05:33 PM
perfectly, it just wont have the slight raised edge on the OD on the end like the OE piece. Haven't had one leak yet and 1or 2 worm clamps or 1 worm clamp/1 corbin clamp (corbin clamps keep constant tension better but over less area) would virtually guarantee no leaks. After you cut it bevel the edge
Re: Edelbrock Performer gaskets and stuff. [Re: RapidRobert] #656195
03/31/10 07:38 PM
03/31/10 07:38 PM
Lubbock, TX
E
Erics5th Offline OP
UsedtobeSatellite6
Erics5th  Offline OP
UsedtobeSatellite6
E
Lubbock, TX
Cool, will do then. Would rather spend 2.99 at Ace than 80 plus bucks at the dealer!
Eric
