Edelbrock Performer gaskets and stuff.
#656191
03/30/10 07:39 PM
03/30/10 07:39 PM
Posts: 3,472 Lubbock, TX
Erics5th
UsedtobeSatellite6
UsedtobeSatellite6
Lubbock, TX
Will regular old Felpro gaskets be ok to use, or do I need the Edelbrock gaskets? Also, the bypass fitting that goes into the manifold I found at the local dealer wanted $83 dollars for it..will a 3" 3/4" NPT piece of pipe work? Is the heater hose 5/8"? This is replacing the Eddy SP2P manifold on my '84 5th Avenue, 318. Thanks.
Eric
