Rotella T oil #656127
03/30/10 06:46 PM
03/30/10 06:46 PM
Colorado
hemiluver Offline OP
Colorado
Any of you high HP flat tappet guys ever use Rotella T oil? If so do you like it?
Thanks-Gary
Re: Rotella T oil [Re: hemiluver] #656128
03/30/10 06:49 PM
03/30/10 06:49 PM
New State
kidmopar Offline
kidmopar  Offline
New State
I use it in my 1970 440 Sixpack. Works great!
Re: Rotella T oil [Re: kidmopar] #656129
03/30/10 06:50 PM
03/30/10 06:50 PM
Colorado
Colorado
Does anybody know how much zinc it has? The web doesnt say?
Thanks-Gary
Re: Rotella T oil [Re: hemiluver] #656130
03/30/10 07:00 PM
03/30/10 07:00 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I've used the 30 wt in the past with good results and will probably use it in my new 440.
You might try www.bobistheoilguy.com to find the amount of zinc.
Nautilus Racing-
Re: Rotella T oil [Re: hemiluver] #656131
03/30/10 07:28 PM
03/30/10 07:28 PM
Wherever I am.
Junky Offline
Junky  Offline
Wherever I am.
Thanks-Gary
The CJ4 has about 1150 to 1250 (iirc) ppm zink according to oil analysis posted on Bob Is The Oil Guy's web site.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
Re: Rotella T oil [Re: Junky] #656132
03/30/10 10:59 PM
03/30/10 10:59 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
It doesn't have as much zinc as it used to, but still a very good oil. I use it to break in my fresh engines, but change it to a heavier race oil afterwards. (like VR-1 or Pennsoil). I also run it in my diesel truck.
Re: Rotella T oil [Re: '72CudaRacer] #656133
03/30/10 11:34 PM
03/30/10 11:34 PM
IN
ahy Offline
ahy  Offline
IN
I've used it in a moderatly aggressive flat tappet along with STP for insurance. All is well at 5,000 miles. I run 15W40. 10W30 is available also at Walmart. As posted above, I understand zinc is lower than it used to be but still pretty high.
Re: Rotella T oil [Re: ahy] #656134
03/31/10 07:47 AM
03/31/10 07:47 AM
what i have heard is that the rotella T diesel oil foams at high rpm's, the reason its good for diesel motors is that they dont rev high enough for foaming to occur.
i know the zinc content is down but still pretty good otherwise.
