How does a Shaker hood drain water? #655745
03/30/10 11:35 AM
03/30/10 11:35 AM
eastern, pa.
cudabitten Offline OP
eastern, pa.
Hey just wondering about this. I was considering doing a shaker conversion later on but could not see any way for water to drain from around the air intake housing. I know there is a gasket there, but does that fill up with water?
Re: How does a Shaker hood drain water? [Re: cudabitten] #655746
03/30/10 11:43 AM
03/30/10 11:43 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
The originals have 2 drain tubes on front of shaker base.
Re: How does a Shaker hood drain water? [Re: buildanother] #655747
03/30/10 12:42 PM
03/30/10 12:42 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
So do the repos...
Re: How does a Shaker hood drain water? [Re: Challenger 1] #655748
03/30/10 04:17 PM
03/30/10 04:17 PM
chicagoland,usa
chicagoland,usa
Awesome.
Re: How does a Shaker hood drain water? [Re: cudabitten] #655749
03/31/10 12:31 AM
03/31/10 12:31 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Connect some short 5/8" heater hose to each drain nipple to drain the water down & off the motor.
Re: How does a Shaker hood drain water? [Re: Triggerfish] #655750
03/31/10 01:32 AM
03/31/10 01:32 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Most I've measured were about 12.00" long, routing of the drain hoses down through the various engine componants varied but usually routed straight down in front of the heads (on Hemis anyway). Here is an original bubble & hoses that shows what they look like. FWIW this is a VERY original "survivor" quality 1971 setup that has never been restored, all original paint, etc. it's shown here on a 1970 Cuda.
Re: How does a Shaker hood drain water? [Re: ScottSmith_Harms] #655751
03/31/10 01:32 AM
03/31/10 01:32 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Bubble removed
Re: How does a Shaker hood drain water? [Re: ScottSmith_Harms] #655752
03/31/10 01:33 AM
03/31/10 01:33 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
With AC lid and filter removed
Re: How does a Shaker hood drain water? [Re: ScottSmith_Harms] #655753
03/31/10 01:34 AM
03/31/10 01:34 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
With Base Plate and Adapter ring assembly removed
Re: How does a Shaker hood drain water? [Re: ScottSmith_Harms] #655754
03/31/10 01:35 AM
03/31/10 01:35 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
bubble underside
Re: How does a Shaker hood drain water? [Re: ScottSmith_Harms] #655755
03/31/10 01:35 AM
03/31/10 01:35 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Adapter ring & base top
Re: How does a Shaker hood drain water? [Re: ScottSmith_Harms] #655756
03/31/10 01:36 AM
03/31/10 01:36 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Adapter ring and base underside
Re: How does a Shaker hood drain water? [Re: ScottSmith_Harms] #655757
03/31/10 01:36 AM
03/31/10 01:36 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Bubble drain tubes that sit down into the adapter ring drain tubes to direct water into them
Re: How does a Shaker hood drain water? [Re: ScottSmith_Harms] #655758
03/31/10 05:07 AM
03/31/10 05:07 AM
the frozen wastes...
Pale_Roader Offline
Swears too much
Pale_Roader  Offline
Swears too much
Wow, Scott, you really know how to answer a question. Thanks, i was wondering that too some time ago.
And Challenger 1, that 71 in your sig is just badass.
Re: How does a Shaker hood drain water? [Re: Pale_Roader] #655759
03/31/10 06:52 AM
03/31/10 06:52 AM
Cincinnati, Ohio
Cincinnati, Ohio
Thanks...
Re: How does a Shaker hood drain water? [Re: Challenger 1] #655760
03/31/10 08:16 AM
03/31/10 08:16 AM
eastern, pa.
eastern, pa.
Yes, as most times, the knowledge base and helpfulness is amazing on this site.
Thanks.
If and when I get to this conversion, I'll ask about how to convert a flat hood to a shaker, but I'm at least a year away. I'll save this thread for reference.
Re: How does a Shaker hood drain water? [Re: ScottSmith_Harms] #655761
03/31/10 08:41 AM
03/31/10 08:41 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
well done Mr Scott
