Interesting electrical question
#655090
03/29/10 07:07 PM
03/29/10 07:07 PM
Posts: 301 wisconsin
swifter
wisconsin
OK-- Just put my new dash assembly in"Fast Lane west" for what I thought was for the last time HaHa,SO I went to try everything out--Now when I apply the brakes the turn signal lights light up on the dash ??? otherwise everything works the way it should blinkers,Hazards --Now I did change from a gm style headlight switch(painless) to a Mopar original headlight switch--What did I wire wrong
If you can point me in the right direction-- PS__ when I tried everything with the GM type switch this did not happen Thanks Steve
2007 Ram 2500 Cummins
2008 Dodge Nitro
1970 340 Valiant Duster
Re: Interesting electrical question
[Re: buildanother]
#655092
03/29/10 07:17 PM
03/29/10 07:17 PM
swifter
wisconsin
N0 Just the turn signals man I went to the extreme on the grounding did not want any ground issues--Steve
2008 Dodge Nitro
[Re: swifter]
#655094
03/29/10 07:35 PM
03/29/10 07:35 PM
Posts: 1,609 Southern Cal
Noblewk
Southern Cal
I agree with the ground issue. When you say "turn signal lights" do you mean both of them in the dash or all 4 plus the dash. Also if it is all 4 will they blink when pressing the brake. Back in the 70's my cousin had a 4 speed car that would have his "reverse" lights on when he turned on his radio.
66 Dart GT, 402 11.18:109 Best
63 1/2 Galaxie 500XL 406 4Speed 13.20:103 Best
2000 Ram
2005 Durango Hemi.
[Re: RemCharger]
#655095
03/29/10 07:35 PM
03/29/10 07:35 PM
Posts: 1,030 JAX FLA
Curt
JAX FLA
Just wondering if you are using a fiberglass front lower valance? Curt
Oh yeah...THAT'S gonna leave a mark!
[Re: Curt]
#655096
03/29/10 07:41 PM
03/29/10 07:41 PM
swifter
wisconsin
No plastic and It is just the turn signal indicators on the dash you know the left and right indicators --Steve
2008 Dodge Nitro
[Re: swifter]
#655097
03/29/10 07:47 PM
03/29/10 07:47 PM
Noblewk
Southern Cal
Ground the dash backplane to your steering column and your problem should go away.
2000 Ram
2005 Durango Hemi.
[Re: Noblewk]
#655098
03/29/10 08:13 PM
03/29/10 08:13 PM
swifter
wisconsin
Dash backplane??? these are all autometer gauges in a fast lane west insert all the gauges are grounded separate to one main ground--could it be the ground from the headlight switch this is also grounded separate--Steve this did not happen with gm headlight switch only with the mopar headlight switch that's why i think i got some wiring messed up when i switched back to the mopar switch
2008 Dodge Nitro
[Re: swifter]
#655099
03/29/10 08:20 PM
03/29/10 08:20 PM
Noblewk
Southern Cal
What are the "turn indicators" grounded to?
2000 Ram
2005 Durango Hemi.
[Re: SixDRacing]
#655101
03/29/10 08:45 PM
03/29/10 08:45 PM
swifter
wisconsin
Everything works great--turn signals--hazards but when i push on the brake the turn signal indicators come on--yes everything works like it should turn signals flash--hazards work --the gauges are grounded directly to the main ground from the batt I ran to the front of the car
2008 Dodge Nitro
[Re: RapidRobert]
#655103
03/30/10 08:19 AM
03/30/10 08:19 AM
Posts: 518 COLLINGWOOD, ONT
71_deputy
COLLINGWOOD, ONT
does the front marker lights turn on too??? what about the rears??? if the fronts do and the rears not- then the wiring is reversed in the turn signal switch from front to back! normally when brake is turned on- only power to the rear lights are on- front and dash signals are not part of the brake circuit. so if your not using a factory mopar harness or someone has been monkeying around by resplicing the wires- you have a problem. first double check the wiring at the turn signal switch to make sure nothing is changed. also make sure the tail lights are both grounded good!!! my
[Re: Curt]
#655106
03/30/10 06:58 PM
03/30/10 06:58 PM
Curt
JAX FLA
I used a fiberglass lower valance and a similar thing happened except when I turned on the headlights the indicators glowed dimly. Ran a ground to the combo front lamps and problem went away Curt
