Six Pack secondary opening rate tuning #654773
03/29/10 01:09 PM
03/29/10 01:09 PM
Space Station #5
471Magnum Offline OP
Space Station #5
Working on getting the bog/surge out of my Challenger when the secondaries kick. Pulled a diaphragm apart to confirm what springs are in it (yellow).
In the process I got to wondering why no one has come out with a quick change spring kit for these, or better yet, an adjustable pod like the QuickFuel set-up for four barrels.
Seems like the latter wouldn’t be too difficult to implement on a Six Pack. Just need some sort of adjustable bleed before the Tee on the vacuum hoses.
Anybody tried anything like this?
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Six Pack secondary opening rate tuning [Re: 471Magnum] #654774
03/29/10 02:50 PM
03/29/10 02:50 PM
Houston, Tx
hemi68charger Offline
Houston, Tx
...In the process I got to wondering why no one has come out with a quick change spring kit...
They used to sell the secondary diaphram spring kits back in the day...
Also, I found this..
http://www.quickfueltechnology.com/main-body-parts/quick-set-adj-sec-housing.html
http://www.quickfueltechnology.com/main-body-parts/vacuum-secondary-spring-kit.html
Troy
Houston Mopar Connection Club
Re: Six Pack secondary opening rate tuning [Re: 471Magnum] #654775
03/29/10 10:28 PM
03/29/10 10:28 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
need more info !
engine , cam, vacuum at idel , ignition timing inital, total , advance rate,center main jet size , power valve no.
Re: Six Pack secondary opening rate tuning [Re: calrobb2000] #654776
03/30/10 12:05 AM
03/30/10 12:05 AM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
Slow them down. People always think they need to be opened quicker.
Re: Six Pack secondary opening rate tuning [Re: 471Magnum] #654777
03/30/10 09:30 AM
03/30/10 09:30 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
i danced thru this last year. my problem was fuel pressure/volume. do a test. also check float levels and filter restrictions. the opening rate will change about 300-400rpm per spring change. every change to a stiffer spring above the yellows will about a tenth to the e.t.
Re: Six Pack secondary opening rate tuning [Re: lewtot184] #654778
03/30/10 09:35 AM
03/30/10 09:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I just bought the kit of springs. I'll be taking them to the track and seeing which works best.
Coming soon!!!!
Re: Six Pack secondary opening rate tuning [Re: Mr.Yuck] #654779
03/30/10 03:55 PM
03/30/10 03:55 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
if you would put a 50cc pump on the center carb and a 35 squirter, most of your troubles and wasting time changing springs would be over.
Re: Six Pack secondary opening rate tuning [Re: Mr.Yuck] #654780
03/30/10 07:49 PM
03/30/10 07:49 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
This is the only way to get the opening rate correct for max power. Tuning to eliminate the hesitation on the street, especially from a roll, may not result in max track performance.
Re: Six Pack secondary opening rate tuning [Re: lewtot184] #654781
03/30/10 07:55 PM
03/30/10 07:55 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
...every change to a stiffer spring above the yellows will about a tenth to the e.t.
Lew, I think I know what you are saying here, but it might not be clear to others.
Re: Six Pack secondary opening rate tuning [Re: 471Magnum] #654782
03/30/10 08:34 PM
03/30/10 08:34 PM
Space Station #5
Space Station #5
Just to be clear, I have the knowledge and experience to tune through this issue. I know it's just a matter of heavier springs or tweaking the pump shot (or maybe fuel starvation).
I'm just looking to make the spring swap easier/unnecessary. It's very difficult to open up the pods without tearing the diaphragms. I grease the screws on reassembly to help prevent snagging/tears, but they happen, and diaphragms are $30.
-Jim
Re: Six Pack secondary opening rate tuning [Re: 471Magnum] #654783
03/31/10 05:56 AM
03/31/10 05:56 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
How do you have your ignition timing set-up? What's your initial and how much mechanical do you have? When does it all come in by?
Check your float levels. Where do you have them set at?
Do you have any vacumm leaks anywhere at all?
Re: Six Pack secondary opening rate tuning [Re: 471Magnum] #654784
03/31/10 10:17 AM
03/31/10 10:17 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
It's not just the spring that controls secondary opening, the kill bleed also has a part in when the end carbs open.
Basically, the kill bleed controls the RPM when they start to open, the spring controls the opening rate (how long they take to fully open).
It's doubtful your bog/surge problem is the opening rate, it most likley one of these;
Not enough accelerator pump shot
Not enough initial timing
Sticking throttle plates
Clogged air bleeds or main circuits in the carbs
