Six Pack secondary opening rate tuning
#654773
03/29/10 01:09 PM
03/29/10 01:09 PM
Posts: 3,719 Space Station #5
471Magnum
Space Station #5
Working on getting the bog/surge out of my Challenger when the secondaries kick. Pulled a diaphragm apart to confirm what springs are in it (yellow). In the process I got to wondering why no one has come out with a quick change spring kit for these, or better yet, an adjustable pod like the QuickFuel set-up for four barrels. Seems like the latter wouldn’t be too difficult to implement on a Six Pack. Just need some sort of adjustable bleed before the Tee on the vacuum hoses. Anybody tried anything like this?
-Jim
I can fix it... my old man is a television repairman. He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
Re: Six Pack secondary opening rate tuning
[Re: 471Magnum]
#654775
03/29/10 10:28 PM
03/29/10 10:28 PM
Posts: 2,003 s. e. pa.
calrobb2000
s. e. pa.
hi need more info ! engine , cam, vacuum at idel , ignition timing inital, total , advance rate,center main jet size , power valve no.
[Re: 471Magnum]
#654777
03/30/10 09:30 AM
03/30/10 09:30 AM
Posts: 3,916 usa
lewtot184
usa
i danced thru this last year. my problem was fuel pressure/volume. do a test. also check float levels and filter restrictions. the opening rate will change about 300-400rpm per spring change. every change to a stiffer spring above the yellows will about a tenth to the e.t.
[Re: Mr.Yuck]
#654780
03/30/10 07:49 PM
03/30/10 07:49 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
I just bought the kit of springs. I'll be taking them to the track and seeing which works best.
This is the only way to get the opening rate correct for max power. Tuning to eliminate the hesitation on the street, especially from a roll, may not result in max track performance.
[Re: lewtot184]
#654781
03/30/10 07:55 PM
03/30/10 07:55 PM
BSB67
Prospect, PA
...every change to a stiffer spring above the yellows will about a tenth to the e.t.
Lew, I think I know what you are saying here, but it might not be clear to others.
[Re: 471Magnum]
#654782
03/30/10 08:34 PM
03/30/10 08:34 PM
471Magnum
Space Station #5
Just to be clear, I have the knowledge and experience to tune through this issue. I know it's just a matter of heavier springs or tweaking the pump shot (or maybe fuel starvation).
I'm just looking to make the spring swap easier/unnecessary. It's very difficult to open up the pods without tearing the diaphragms. I grease the screws on reassembly to help prevent snagging/tears, but they happen, and diaphragms are $30.
-Jim
[Re: 471Magnum]
#654783
03/31/10 05:56 AM
03/31/10 05:56 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
How do you have your ignition timing set-up? What's your initial and how much mechanical do you have? When does it all come in by?
Check your float levels. Where do you have them set at?
Do you have any vacumm leaks anywhere at all?
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
