Radiator Plugged Cleaning It? #653408
03/28/10 11:17 AM
03/28/10 11:17 AM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Hey Guys, I have been working on my friends 67 Coronet that he put a 360 in. We bought a used 26" radiator at a swap meet for $30 and put it in. The car is getting a little warm and when I feel the front of the radiator some areas are cooler than others. I took it back out and ran a hose in it and the water came out as fast as it was going in. But I did get some junk to come out and there is some scale built up in it. Is there any product or home remedies that would clean it out or should I bring it to get cooked at a radiator shop?
Thanks Scott!
1966 Coronet 440 conv. original Mauve metallic, with white top and interior. 1971 360, J heads, 625 AFB, 340 cam, intake, and manifolds. With 3.23 SureGrip.
1969 Dart GT: B5 Blue, White top, 318, With A/C
Re: Radiator Plugged Cleaning It? [Re: ScottG] #653409
03/28/10 11:21 AM
03/28/10 11:21 AM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I have used a mild solution of LYE ... but be careful too harsh of a solution will EAT UP the cores.
Re: Radiator Plugged Cleaning It? [Re: ScottG] #653410
03/28/10 11:25 AM
03/28/10 11:25 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Years ago, I knew someone who capped the lower hose fitting and filled the radiator with CLR and let it sit a while, then flushed it out...seemed to help abit
(I just would have brought it to the local radiator shop myself and let them boil it out )
Re: Radiator Plugged Cleaning It? [Re: ScottG] #653411
03/28/10 11:30 AM
03/28/10 11:30 AM
How warm, what stat, Check the stat opening suspended in a pot of water on the stove w a candy thermometer, drill 1/16" hole for easier fillup/air pockets, around town or hiway, what fan, shroud?, fan spacing, timing good. The 360 ran cool in the donor?, call the rad shop & at least price a boilout
Re: Radiator Plugged Cleaning It? [Re: RapidRobert] #653412
03/28/10 09:06 PM
03/28/10 09:06 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
The radiator shop should be able to remove the tanks and rod it out if the core is worthy
Re: Radiator Plugged Cleaning It? [Re: Mopar-Al] #653413
03/29/10 12:46 AM
03/29/10 12:46 AM
Dirk Offline
Dirk  Offline
I also used the CLR method by laying the rad on it's front with cap on. Fill it 2/3 of the way with CLR and slosh it around every 30 minutes or so for an afternoon. If it is calcium scale from using tap water, it will dissolve in a few hours.
If you can see the tubes inside, you can see which are plugged when you slosh it back and forth.
It is a cheap fix if it works!
Hope this helps.
Re: Radiator Plugged Cleaning It? [Re: Dirk] #653414
03/29/10 05:50 AM
03/29/10 05:50 AM
Ohio
ScottG Offline OP
ScottG  Offline OP
Ohio
Thanks Guys, It's going to the radiator shop so we know its done right!
Scott!
Re: Radiator Plugged Cleaning It? [Re: ScottG] #653415
03/29/10 08:02 AM
03/29/10 08:02 AM
Manistee, Michigan.
High Impact Offline
High Impact  Offline
Manistee, Michigan.
I was always told to fill it with white vingar, like when cleaning a coffee pot. Vingar is a excellent cleaning agent.
Re: Radiator Plugged Cleaning It? [Re: ScottG] #653416
03/29/10 08:46 AM
03/29/10 08:46 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Scott!
I agree with this. The other ways are quicky band aides but don't really get the job done right.. Take it in and have it rodded out and it will last as long as you will need it and longer. It may cost a little more but it is done right.
