Re: need help badly please
[Re: My340Duster]
#65332
05/28/08 09:09 PM
05/28/08 09:09 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
Personally I would do just the opposite. With the engine running I would take a hammer handle and apply pressure to the pushrod end of the noisy rockers and depress the lifters thus force bleeding the air out allowing them to fill with pressurized oil. Has worked in the past many times over. .
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: StandOnIt]
#65335
05/29/08 04:52 PM
05/29/08 04:52 PM
Posts: 4,872 connecticut
pnypwr
connecticut
try setting them hot, the last motor I built i had to adjust them 3 or 4 times till they were quiet at idle...they still make a little noise at rpm but I think its more cam profile and spring pressure...
"Are you gonna bark all day lil doggy? Or are you gonna bite?"
05 ram 2500 ctd 74 gremlin x 360 65 mustang 347 70 coronet R/T 440 03 Mach 1
