Re: The engine is apart... [Re: bad1970dust] #653156
03/29/10 05:47 PM
03/29/10 05:47 PM
tboomer Online work OP
tboomer  Online Work OP
What plan? Call me when you can...I got the 383 lined up!!
Re: The engine is apart... [Re: tboomer] #653157
03/29/10 05:53 PM
03/29/10 05:53 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Jimmy(bad1970dust) gutted my 446" this afternoon...Here is what he found...Cam was junk,had a wiped lobe. Two cylinders were scared..Should clean up at .055 over. Rod bearings were shot. 1 main bearing showed some scars. 1 piston was chewed up on the bottom and probably some other things I forgot!! Looks like back to the drawing board!!
Where is Jimmy from? I had Brian Keck from Quimby do my stroker . Its 99% done, I qlicking the heads on it shortly, and The cars getting done, so SOON ill be rowing the gears again..
Hope ya get a new bullet in her soon, its almost cruising weather.
Kasey
Re: The engine is apart... [Re: Moparnut426] #653158
03/29/10 05:57 PM
03/29/10 05:57 PM
Jimmy has a shop in Story City,Iowa...Great Mopar mechanic....Cooks a good turkey,too...Except once!!
Re: The engine is apart... [Re: tboomer] #653159
03/29/10 06:08 PM
03/29/10 06:08 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Kind words always make my day a little better!! Thanks,everyone!! I may pick up an old 383,slap my cam and heads to it and race Sportsman et...Leigh....Me think this year the Dart will beat me to the track!!
Sorry to hear the bad news..
But you may want to rethink the 383 deal, built properly you will wonder why you ran RB stuff in the first place...
Re: The engine is apart... [Re: tboomer] #653160
03/29/10 06:13 PM
03/29/10 06:13 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
ted if vernmotor does not want to use my 440 you are more than welcome to use it. all you need is some push rods, rockers and a intake.let me know if yuo are interested in it. it still has 80 pounds of oil pressure and checked at 165 pis crancking compression.this engine got my old 3600 pound 65 plymouth down into the 11.70 range. best of luck bobby
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: The engine is apart... [Re: mopar65] #653161
03/29/10 06:20 PM
03/29/10 06:20 PM
Bobby...You are more than kind,thanks for the offer..But as Jimmy said...Stick with the plan!! I heard that years ago from a young fella up North with a GTX....Should have listened to him!! Wouldn't be in this pickle!! Moparts racers rule!! You guys are proof of that!!....Vern...If ya need anything I have...Let me know...Don't have much...But we are all gonna race this year!!
Re: The engine is apart... [Re: tboomer] #653162
03/29/10 08:18 PM
03/29/10 08:18 PM
Northern Indiana
Dunnuck Racing Offline
Northern Indiana
What does Vernmotor need?Last I remember he had a transmission issue,and resolved it.Did he hurt the engine after that?
Re: The engine is apart... [Re: Dunnuck Racing] #653163
03/29/10 08:34 PM
03/29/10 08:34 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Yes, Vern found a rusty spark pulg in a Cyl that he had replaced a cracked sleeve in.
https://board.moparts.org/ubbthreads/show...e=4#Post5892626
Re: The engine is apart... [Re: WILD BILL] #653164
03/29/10 08:39 PM
03/29/10 08:39 PM
Northern Indiana
Northern Indiana
So is there any other damage?Or does he need a block and some rebuild parts?
Re: The engine is apart... [Re: Dunnuck Racing] #653165
03/29/10 08:42 PM
03/29/10 08:42 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Last I heard he hadn't started the autopsy yet
Re: The engine is apart... [Re: WILD BILL] #653166
03/29/10 08:45 PM
03/29/10 08:45 PM
Northern Indiana
Northern Indiana
Thanks,Bill!
Re: The engine is apart... [Re: Dunnuck Racing] #653167
03/29/10 08:56 PM
03/29/10 08:56 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
Well I look at it some more tonight,,No water/anitfreeze in the oil.. I going to put the trans in so I can crank it over with the starter and see what come out of this spark plug hole. do a leak down . blow some air in that hole and see just how bad it is. I might give the block seal a try..or take the head off and look in there..Ted If you need anything let Me know I got lots of blocks..I got almost a spare motor here. would have to buy some parts..
Re: The engine is apart... [Re: VernMotor] #653168
03/30/10 12:52 AM
03/30/10 12:52 AM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
i also vote for " Stick to the Plan Theodore !!
hand over your parts and some cash to Jim and you wont have to worry anymore........ plus you will end up with a kick as.s engine
if you outrun me.........i might have to put a blue bottle in my trunk....
Re: The engine is apart... [Re: 493_DART] #653169
03/30/10 05:36 PM
03/30/10 05:36 PM
Keith and Vern...You have a pm... Kevin...Got all of the parts I needed from a local fella!! And....The price was right!! I also have a feeling that you won't need a bottle...
Re: The engine is apart... [Re: tboomer] #653170
03/30/10 10:56 PM
03/30/10 10:56 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
OK so what's the new combination? Top secret?
Or are we making it up as we go (my favorite)
Rich H.
Esse Quam Videri
Re: The engine is apart... [Re: ZIPPY] #653171
03/31/10 10:24 AM
03/31/10 10:24 AM
Rich...We are winging it as we go...Hope to get low 12s out of the 383...
Re: The engine is apart... [Re: tboomer] #653172
03/31/10 01:01 PM
03/31/10 01:01 PM
iowa
bad1970dust Offline
"Hollywood"
bad1970dust  Offline
"Hollywood"
iowa
ted if we do that if i put a stop on the ladys car you might be able to keep up.
Re: The engine is apart... [Re: bad1970dust] #653173
03/31/10 01:05 PM
03/31/10 01:05 PM
Jimmy...The parts are going to Steves shop...Watch for them!!
Re: The engine is apart... [Re: tboomer] #653174
03/31/10 01:33 PM
03/31/10 01:33 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I'll get that gently used .509 purple shaft shipped to you right away buddy
Re: The engine is apart... [Re: ZIPPY] #653175
03/31/10 01:46 PM
03/31/10 01:46 PM
Thanks,Rich!!
