Re: The engine is apart...
[Re: tboomer]
#653157
03/29/10 05:53 PM
03/29/10 05:53 PM
Posts: 12,013 Finally a HUSKER again
Moparnut426
Jimmy(bad1970dust) gutted my 446" this afternoon...Here is what he found...Cam was junk,had a wiped lobe. Two cylinders were scared..Should clean up at .055 over. Rod bearings were shot. 1 main bearing showed some scars. 1 piston was chewed up on the bottom and probably some other things I forgot!! Looks like back to the drawing board!!
Where is Jimmy from? I had Brian Keck from Quimby do my stroker . Its 99% done, I qlicking the heads on it shortly, and The cars getting done, so SOON ill be rowing the gears again..
Hope ya get a new bullet in her soon, its almost cruising weather.
Kasey
[Re: tboomer]
#653159
03/29/10 06:08 PM
03/29/10 06:08 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
Kind words always make my day a little better!! Thanks,everyone!! I may pick up an old 383,slap my cam and heads to it and race Sportsman et...Leigh....Me think this year the Dart will beat me to the track!!
Sorry to hear the bad news.. But you may want to rethink the 383 deal, built properly you will wonder why you ran RB stuff in the first place...
[Re: Dunnuck Racing]
#653165
03/29/10 08:42 PM
03/29/10 08:42 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Last I heard he hadn't started the autopsy yet
[Re: 493_DART]
#653169
03/30/10 05:36 PM
03/30/10 05:36 PM
Posts: 25,979 United Socialist States of Ame...
tboomer
Keith and Vern...You have a pm... Kevin...Got all of the parts I needed from a local fella!! And....The price was right!! I also have a feeling that you won't need a bottle...
[Re: tboomer]
#653170
03/30/10 10:56 PM
03/30/10 10:56 PM
Posts: 17,904 S.E. Michigan
ZIPPY
S.E. Michigan
OK so what's the new combination? Top secret? Or are we making it up as we go (my favorite)
Rich H.
Esse Quam Videri
[Re: tboomer]
#653172
03/31/10 01:01 PM
03/31/10 01:01 PM
Posts: 141 iowa
bad1970dust
"Hollywood"
"Hollywood"
iowa
Rich...We are winging it as we go...Hope to get low 12s out of the 383...
ted if we do that if i put a stop on the ladys car you might be able to keep up.
[Re: tboomer]
#653174
03/31/10 01:33 PM
03/31/10 01:33 PM
ZIPPY
S.E. Michigan
I'll get that gently used .509 purple shaft shipped to you right away buddy
