42RH dipstick tube leak
#652679
03/27/10 03:10 PM
03/27/10 03:10 PM
Posts: 954 garnett kansas
rhad
garnett kansas
i have a 95 dakota with a 42RH transmission,and the dipstick tube leaks where it goes into the case,i checked with my cute parts girl at the local dealer,she said it takes a sorta sleeve type seal,so i have her order me two,i get the dipstick tube out and it takes a 'o' ring,she double and triple checks her computer and the sleeve is supposed to fit,no updated tube,its supposed to fit the tube i have,i recall some GM trannnys had a sleeve type seal and the tube was tapered to accept them,not so here,anyone else have this problem?,id rather not use a 'o' ring as ive had problems with them leaking
Re: 42RH dipstick tube leak
[Re: rhad]
#652680
03/27/10 03:42 PM
03/27/10 03:42 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
mopar dip stick tubes have taken an o ring for about a 1000 years. put a new one in and it will stop leaking.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
[Re: rhad]
#652681
03/27/10 06:15 PM
03/27/10 06:15 PM
Posts: 25,902 Rio Linda, CA
John_Kunkel
Rio Linda, CA
First, be sure the leak is at the O ring; the tube is beaded inward to accept the O ring and the tube often cracks at the bead. If the O ring is the leak source, a little RTV around the O ring before installation helps the seal.
[Re: rhad]
#652683
03/28/10 05:57 PM
03/28/10 05:57 PM
John_Kunkel
Rio Linda, CA
Gobs of RTV will seal it even with no O ring, just be sure the fluid level is well below the tube and both surfaces clean.
[Re: 1100HPSmallBlock]
#652686
03/30/10 06:57 AM
03/30/10 06:57 AM
Posts: 16,123 Grand Haven, MI
patrick
Grand Haven, MI
I think it's 96 or 98, they switched to the boot type seal. it uses a different dipstick tube with a sweged end reduced to about 5/8" OD. I modded a '98 dakota dipstick tube to fit my M body because I was tired of leaks with the O-rings..
