42RH dipstick tube leak #652679
03/27/10 03:10 PM
03/27/10 03:10 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
i have a 95 dakota with a 42RH transmission,and the dipstick tube leaks where it goes into the case,i checked with my cute parts girl at the local dealer,she said it takes a sorta sleeve type seal,so i have her order me two,i get the dipstick tube out and it takes a 'o' ring,she double and triple checks her computer and the sleeve is supposed to fit,no updated tube,its supposed to fit the tube i have,i recall some GM trannnys had a sleeve type seal and the tube was tapered to accept them,not so here,anyone else have this problem?,id rather not use a 'o' ring as ive had problems with them leaking
Re: 42RH dipstick tube leak [Re: rhad] #652680
03/27/10 03:42 PM
03/27/10 03:42 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
mopar dip stick tubes have taken an o ring for about a 1000 years. put a new one in and it will stop leaking.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: 42RH dipstick tube leak [Re: rhad] #652681
03/27/10 06:15 PM
03/27/10 06:15 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
First, be sure the leak is at the O ring; the tube is beaded inward to accept the O ring and the tube often cracks at the bead. If the O ring is the leak source, a little RTV around the O ring before installation helps the seal.
Re: 42RH dipstick tube leak [Re: John_Kunkel] #652682
03/28/10 11:31 AM
03/28/10 11:31 AM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
i inspected the tube closer and it has a deeper groove one one side than the other,looks like it might have been bent slightly and not letting the O ring seat correctly,so its either new tube time,or cut and weld a new bottom end on it
Re: 42RH dipstick tube leak [Re: rhad] #652683
03/28/10 05:57 PM
03/28/10 05:57 PM
Rio Linda, CA
Rio Linda, CA
Gobs of RTV will seal it even with no O ring, just be sure the fluid level is well below the tube and both surfaces clean.
Re: 42RH dipstick tube leak [Re: John_Kunkel] #652684
03/28/10 07:45 PM
03/28/10 07:45 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
i know they can be sealed with RTV and ive done that and seen them leak later on,im gonna go for a new tube if i can get one that uses the new sleeve seal,if not i might weld the end of a gm sleeve type on my tube,can i weld a drain plug in the 42RH pan?,if so where?i considered drilling a hole in it on the truck,but my luck id drill into the VB,i want to use the mopar resueable gasket,they CLAIM that it dont leak?
Re: 42RH dipstick tube leak [Re: rhad] #652685
03/29/10 05:13 PM
03/29/10 05:13 PM
Mo.
1100HPSmallBlock Offline
Mo.
Fix it for good with the "Boot Type" seal. Cut 1 1/2 inches off the bottom of the tube,spread a little silicone inside this repair end and jam it on there! http://www.transmissionpartsusa.com/Transmission_dipstick_tube_repair_p/002-0000t9999.htm
http://www.transmissionpartsusa.com/Transmission_filler_tube_grommet_seal_p/490-000049266.htm
Re: 42RH dipstick tube leak [Re: 1100HPSmallBlock] #652686
03/30/10 06:57 AM
03/30/10 06:57 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
I think it's 96 or 98, they switched to the boot type seal. it uses a different dipstick tube with a sweged end reduced to about 5/8" OD. I modded a '98 dakota dipstick tube to fit my M body because I was tired of leaks with the O-rings..
2017 Grand Cherokee Overland
Re: 42RH dipstick tube leak [Re: patrick] #652687
03/30/10 06:14 PM
03/30/10 06:14 PM
garnett kansas
rhad Offline OP
rhad  Offline OP
garnett kansas
i installed a new tube today with a o ring for a seal,if it leaks,im gonna do something different,the later tube that uses a sleeve seal sounds right
thanks everyone for your input
