csr trans shield #652581
03/27/10 11:10 AM
03/27/10 11:10 AM
mo
moparbud Offline OP
moparbud  Offline OP
mo
i am thinging about buying a csr trans shield part #csr 836 has any one used one and will they clear the stock floor and fire wall my car is a 68 roadrunner 440/727 trans let me know your opions or is there a better one thanks
Re: csr trans shield [Re: moparbud] #652582
03/27/10 11:14 AM
03/27/10 11:14 AM
Nazareth,Pa.
JACKSON Offline
JACKSON  Offline
Nazareth,Pa.
Do a search, this topic is beat to death,if you catch my drift!
Re: csr trans shield [Re: moparbud] #652583
03/27/10 11:30 AM
03/27/10 11:30 AM
DANBURY CT
fury62 Offline
fury62  Offline
DANBURY CT
I have a 62 fury b body, 440, 727 on the shield there is a raised rib towards the back. I had to dimple in the tunnel with a ball peen hammer. it fits ok. your tunnel may be larger.
Re: csr trans shield [Re: fury62] #652584
03/27/10 04:43 PM
03/27/10 04:43 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
You may (read, most likely) have to "adjust" your transmission tunnel, but it should fit.
Brian
Re: csr trans shield [Re: '72CudaRacer] #652585
03/27/10 08:04 PM
03/27/10 08:04 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline
i advise putting the motor and tranny together then installing them as a unit..
the allen head bolts are next to impossible to reach. insert a socket into them when in the car.
youll have to cut off a boss section of the bell housing to get it on..
i had to flatten the factory pinch seam for it to clear the tunnel as well.
cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
