Re: csr trans shield
[Re: fury62]
#652584
03/27/10 04:43 PM
03/27/10 04:43 PM
Posts: 2,048 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
You may (read, most likely) have to "adjust" your transmission tunnel, but it should fit. Brian
[Re: '72CudaRacer]
#652585
03/27/10 08:04 PM
03/27/10 08:04 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
i advise putting the motor and tranny together then installing them as a unit.. the allen head bolts are next to impossible to reach. insert a socket into them when in the car. youll have to cut off a boss section of the bell housing to get it on.. i had to flatten the factory pinch seam for it to clear the tunnel as well. cheapst
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
