413 motorhome engine ???"s
#651550
03/26/10 06:12 AM
03/26/10 06:12 AM
Posts: 1,567 Ky
jt4406
Ky
Had the opportunity yesterday to buy a 413 engine out of a motorhome. It was complete with a holley carb (looked to be one with a governor). I passed on it. It had the industrial waterpump setup on it so I figured the heads, intake, carb, exhaust, were all basically useless. It had a small diameter balancer, didn't look to be externally balanced, but not the same diameter as a steel 440 crank would have had. Do you guys know if the block, crank and rods were useful in an automotive application? thanks Jess
Yeah, it's hopped up to over 160...
Re: 413 motorhome engine ???"s
[Re: RC91]
#651554
03/26/10 10:30 AM
03/26/10 10:30 AM
Posts: 15,995 RI Deep in the rust belt
chargervert
I have a 413 Motor home engine,and it says 265 horsepower right on the air cleaner lid.
70 Charger R/T SE 472 Hemi
70 Charger R/T convertible
70 Charger R/T V Code Sixpack
69 Charger R/T SE Sunroofcar
68 Charger 383
68 Charger 318
71 Charger R/T
70 Challenger convertible
71 Challenger convertible
71 Cuda 340
09 Challenger R/T Classic
[Re: Challenger 1]
#651556
03/26/10 12:31 PM
03/26/10 12:31 PM
Posts: 30,460 Florida STAYcation
dOOc
The village idiot's idiot
Florida STAYcation
Where's Doc fiberglass? I bet he knows.
You rang ? ..
To the OP ... you passed on it ? .. how much were they asking for it? I have seen a JY asking as much as 1000$ ...and as little as 125$(with a trans) in a burned-out MH .... toasted because the Berry crab started leaking like a sieve ....and burned the front half of the MH almost to-the-ground !!!
IS this motor usable in a car .....as-is ? If you want a GRUNT motor and if you want to heavily modify the exh mans .. sure. But the entire combo is more suited to a motorhome/truck application.
Should you toss all those parts you mention? ... YEAH ... TOSS 'EM over here ! I am doing some serious R%D with this combo and am saving all these parts I can.
Are the parts that you mention worth saving? ... I say yes. Are they as good as a typical 440 HP combo ? ... probably not - as some would suggest.
But then did the smaller-bore Max-Wedge run pretty good ?
Yup ! ..
""""""""""Had the opportunity yesterday to buy a 413 engine out of a motorhome. It was complete with a holley carb (looked to be one with a governor). I passed on it. It had the industrial waterpump setup on it so I figured the heads, intake, carb, exhaust, were all basically useless. It had a small diameter balancer, didn't look to be externally balanced, but not the same diameter as a steel 440 crank would have had. Do you guys know if the block, crank and rods were useful in an automotive application? """""""""""
[Re: dOOc]
#651557
03/26/10 12:55 PM
03/26/10 12:55 PM
chargervert
The one I have is complete,carb to pan,with trans,and it runs. The first person to put $400.00 in my hand can take it.
68 Charger 383
68 Charger 318
71 Charger R/T
71 Cuda 340
[Re: chargervert]
#651559
03/26/10 03:03 PM
03/26/10 03:03 PM
dOOc
Florida STAYcation
In my experience .... your hand is going to be OUT THERE a long LONG time !
[Re: RC91]
#651560
03/26/10 03:05 PM
03/26/10 03:05 PM
dOOc
Florida STAYcation
Dodge 1971/72 V8- 413-1 4 BBL 4.188 X 3.75 7.5 to 1 265 @ 4000 445 fp @ 2400 Sodium Ex. Valves
Dodge 1971/72 V8- 413-3 4 BBL 4.188 X 3.75 7.5 to 1 238 @ 3600 407 fp @ 2000 Sodium Ex. Valves
Dodge 1973 V8- 413-3 4 BBL 4.188 X 3.75 7.5 to 1 190 @ 3200 355 fp @ 2000 Sodium Ex. Valves
Dodge 1976 V8- 413-3 4 BBL 4.188.X 3.75 7.54 to 1 175 @ 3200 325 fp @ 2000
WHERE did you come up with these #'s ?
[Re: dOOc]
#651562
03/26/10 04:06 PM
03/26/10 04:06 PM
Posts: 10 ohio
2young2drive
ohio
[Re: wildfish72]
#651564
09/13/10 11:44 AM
09/13/10 11:44 AM
Posts: 223 Poplar Bluff, Missouri
partfiler69
Still Wondering
Still Wondering
I just picked one of these up, and I am wondering what can be used? I have a 2bbl 383 out of a 70 polara for parts, can I use the 413 intake on the 906 heads? This is a budget build for right now. I just want to know what to hang on to, and what to toss on the scrap trailer.
Back from hiatus
[Re: jt4406]
#651567
09/13/10 01:20 PM
09/13/10 01:20 PM
partfiler69
Still Wondering
Still Wondering
I'm sorry, let me try this again. I want to take the oil pan, pickup tube, heads and water pump housing from the 383 and put it on the 413. Did I forget anything?
Back from hiatus
[Re: partfiler69]
#651568
09/13/10 01:41 PM
09/13/10 01:41 PM
dOOc
Florida STAYcation
YES ... it will work .. but you can do better. Get a set of small chambered heads for more compression(the MH 413 is very weak in that area). And a set of regular 383 heads(906's?) will not help.
In this swap ... watch out for the top two ports of the water pump in the block. On the 413 - using those "goofy" heads ... these ports are more-than-likely plugged with sediment.
[Re: dOOc]
#651569
09/13/10 01:43 PM
09/13/10 01:43 PM
much easier just to take a felt marker and write "413" on the 383's valvecovers... no?
