C&S aerosol billet carb anyone run one? #651428
03/25/10 10:22 PM
03/25/10 10:22 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
I just scored one of these on the auction site. It's a 850 aerosol alcohol carb. Would like to know what to expect. Jim
Re: C&S aerosol billet carb anyone run one? [Re: rt66jim] #651429
03/26/10 04:13 AM
03/26/10 04:13 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Never heard of it before but that doesn't mean much.
At least it a littlefor ya
Re: C&S aerosol billet carb anyone run one? [Re: WILD BILL] #651430
03/26/10 07:44 AM
03/26/10 07:44 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Bill i sent info to you but it was out your league you said .Saving on up on trans parts and motor paint
I run a 950 one love it i use the bypass valve setup .my fuel use went down and could build heat in motor .
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: C&S aerosol billet carb anyone run one? [Re: 10 o to go] #651431
03/26/10 07:56 AM
03/26/10 07:56 AM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I know a lot of guys that run both there aerosal n/a carbs and there aerosal blow through, and everyone says the same thing...one of the best carbs they have ever used
Re: C&S aerosol billet carb anyone run one? [Re: 10 o to go] #651432
03/26/10 09:16 AM
03/26/10 09:16 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Yes, you did I didn't really look at their carbs though
That Bypass is a sweet set up.
Re: C&S aerosol billet carb anyone run one? [Re: WILD BILL] #651433
03/26/10 10:19 AM
03/26/10 10:19 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Jim,
If you want I can get you the phone number for a guy in Bartlesville who has some experience with the aerosol alcohol carbs. He really likes them.
Just let me know.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: C&S aerosol billet carb anyone run one? [Re: Von] #651434
03/26/10 12:06 PM
03/26/10 12:06 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
C&S has been in business for over 30 years, building race carbs, alcohol carbs, by-passes, and belt driven fuel pumps. They are heavy into stock cars as well as drag cars. They have air cleaners for dominators, and even offset aircleaner bases for tight fit applications.
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
Re: C&S aerosol billet carb anyone run one? [Re: Slingshot383] #651435
03/26/10 12:54 PM
03/26/10 12:54 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Thank you for your replies. I guess when it gets here I'll contact C&S for their input for my combo. Jim
Re: C&S aerosol billet carb anyone run one? [Re: rt66jim] #651436
03/26/10 01:35 PM
03/26/10 01:35 PM
corpus christi tex
Cheatham Offline
Cheatham  Offline
corpus christi tex
There should be a number etched on top of the carb, call C&S and give them the number and they will tell you what it was built for, they dont sell off the shelf carbs, every carb they sell is built specific to customer specs, i have an 800 areo. alcohol and a 800 vac sec aero. both built for my 340s but work great on my 440, i couldnt afford the aerosol dominator but i wish i had one
Re: C&S aerosol billet carb anyone run one? [Re: rt66jim] #651437
03/26/10 06:30 PM
03/26/10 06:30 PM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
Roger is the owner he bought it his from uncle ,but worked their.
The pic i posted is close to mine i have the slide fuel log .
I run a barry grant 220 or 280 cant remember .It has a bypass pressure setting .What is needed for their fuel log carb setup is no more than 10lbs pressure .
I cut my piece of the spring to get it psi down .
Your fuel log is the fuel regulator at idle i have about 2 lbs the log valve is open to recirculate back to cell ,as you open throttle
it shuts the valve and put most fuel to carb
works off throttle linkage about 10 lbs.
I have a friend who put one on last week with a fuel regulator ,dont think its going to work that way ,so i'll see tonite .
Don
Re: C&S aerosol billet carb anyone run one? [Re: rt66jim] #651438
03/27/10 12:32 PM
03/27/10 12:32 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I guess no interest in the phone number?
Re: C&S aerosol billet carb anyone run one? [Re: Von] #651439
03/27/10 03:50 PM
03/27/10 03:50 PM
Joplin, Mo
rt66jim Offline OP
rt66jim  Offline OP
Joplin, Mo
Jim,
Just let me know.
Von I will contact C&S when it gets and decide how to proceed. Jim
Re: C&S aerosol billet carb anyone run one? [Re: rt66jim] #651440
03/27/10 11:55 PM
03/27/10 11:55 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
No problem. I was just trying to help you out. This fellow has been around alky carbs and C&S for over twenty years. Thought he might be able to help you.
