Need advice on 41TE #651423
03/25/10 10:14 PM
03/25/10 10:14 PM
Pennsylvania
cantspel Offline OP
cantspel  Offline OP
Pennsylvania
I just overhauled a 41 in a 99 caravan with a 3.3 and used a Dacco converter i got from a local trans shop. I normally use chrysler converters, but the remans have been junky and the dacco was cheaper.......so He gives me a 582Y which is smaller (9 3/4" i think), and bolts to the inner flexplate pattern. It has also apparently raised the stall speed noticeably. I really don't care for it. at times, when idling in gear, the vehicle makes no attempt to move on its own. Trans works fine otherwise, just seems to have too much stall, and I don't like it. My question is, is this normal for this converter, or is this one just junk? And if it is normal, will it have any longterm ill affects on the trans or heat build up in the trans. This minivan has a hitch and sometimes sees a 5x8 utility trailer. Thanks for the help
Re: Need advice on 41TE [Re: cantspel] #651424
03/26/10 08:26 AM
03/26/10 08:26 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I've only used a few aftermkt convertors,mainly due to customer costs or Mopar backorder issues.But I have never experienced anything like that.
I personally wouldn't like it and would question Daaco on it. Something to remember,the Mopar A604 variants do not like heat. So if you keep it in there I would definitly install some kind of external cooler
Re: Need advice on 41TE [Re: gtx6970] #651425
03/27/10 12:06 AM
03/27/10 12:06 AM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
you may have something else going on I use nothing but Dacco converters and I use 5-10 a week and I only had a problem with 1 in the last year.
I have also interchanged the 582y and 585 on many occasions and have never been able to tell a difference in the stall.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Need advice on 41TE [Re: dusturbd340W5] #651426
04/07/10 11:07 AM
04/07/10 11:07 AM
Pennsylvania
cantspel Offline OP
cantspel  Offline OP
Pennsylvania
I wanted to update the couple guys that helped out. I called Dacco and the 582 does have a 1-200 rpm increase in stall. I am sure thats what I am feeling. I have put about 500 miles on this van just running it around, (Its a family members), and it works fine other than the stall speed. So Dacco is sending me a 585-90 to put in its place. I am going to just swap the converter, and nothing else, and see if its fixed. Hopefully I will be able to sleep again. I've done probrobly 2 hundred 604's, it doesn't surprise me that I would have trouble with my in-laws van.
Re: Need advice on 41TE [Re: cantspel] #651427
04/07/10 12:35 PM
04/07/10 12:35 PM
Kissimmee Fl.
Kissimmee Fl.
hope it fixes your concern but like I said above I have iterchanged the 2 many many times with no problems at all.
