I just overhauled a 41 in a 99 caravan with a 3.3 and used a Dacco converter i got from a local trans shop. I normally use chrysler converters, but the remans have been junky and the dacco was cheaper.......so He gives me a 582Y which is smaller (9 3/4" i think), and bolts to the inner flexplate pattern. It has also apparently raised the stall speed noticeably. I really don't care for it. at times, when idling in gear, the vehicle makes no attempt to move on its own. Trans works fine otherwise, just seems to have too much stall, and I don't like it. My question is, is this normal for this converter, or is this one just junk? And if it is normal, will it have any longterm ill affects on the trans or heat build up in the trans. This minivan has a hitch and sometimes sees a 5x8 utility trailer. Thanks for the help
