sleeve a 318 and bore to 340 #650767
03/25/10 06:46 AM
03/25/10 06:46 AM
NC
alpha727 Offline OP
alpha727  Offline OP
NC
Just curious if you could sleeve a 318 then bore it out to 4.04 or higher. Thanks.
Re: sleeve a 318 and bore to 340 [Re: alpha727] #650768
03/25/10 07:53 AM
03/25/10 07:53 AM
Kansas
racincuda Offline
racincuda  Offline
Kansas
Havent priced sleeves lately but it used to be around $100 per hole + boring.
You could probably talk me out of my 69 340 block for less than that, or quite a few others I would guess.
But hey if money is no object then go for it !
oh and pick up a stroker kit to go with it as well
Re: sleeve a 318 and bore to 340 [Re: alpha727] #650769
03/25/10 08:17 AM
03/25/10 08:17 AM
St. Clair Shores, Michigan
bigsbigelow Offline
bigsbigelow  Offline
I don't think it is a bad idea. The motor will have really strong cylinder walls if you decide to do it.
Ryan "Bigs" '73 Duster (BLKDUST) - Black, 100% factory sheet metal, flat hood, 346 cid, J Heads, and a bench seat. http://s268.photobucket.com/albums/jj1/bigsbigelow/ Best to date: 12.40 @ 109 mph
Re: sleeve a 318 and bore to 340 [Re: bigsbigelow] #650770
03/25/10 08:42 AM
03/25/10 08:42 AM
NJ central
Scamp408 Offline
Scamp408  Offline
NJ central
Just buy my X block LOL
Re: sleeve a 318 and bore to 340 [Re: Scamp408] #650771
03/25/10 11:18 AM
03/25/10 11:18 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
I'm sure it could be done, but is the cost worth it? average cost a few years ago for sleeves was $100 a hole...not sure if that's gone up or down in the past year or so, but if you figure that, plus the cost to machine the sleeves afterwards...you're probably looking at $1,000-$1200 to turn a 318 into a 340. how much would a 340 block run you at the swap meets, online, etc.?
**Photobucket sucks**
Re: sleeve a 318 and bore to 340 [Re: 70Cuda383] #650772
03/25/10 11:35 AM
03/25/10 11:35 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
You really need to sonic test it first. It may be able to be bored to 4" (360 size...), but you have to have a little meat to give the sleeve some stability. I'd be concerned about leak posibilities by doing that on all 8. A std 318 type wouldnt concern me. But removing that much wall structure does.
Re: sleeve a 318 and bore to 340 [Re: alpha727] #650773
03/25/10 11:44 AM
03/25/10 11:44 AM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
Just buy a junkyard 360 [ $50.00-$100.00 in my part of the world ]. Almost any 360 can be bored .030 without checking and many can go .060+. .040 over 360 = 367 cu. in. vs 4.04 bore 318 = 340. 360 = low cost, more cubes. Sleeved 318 = high cost, fewer cubes.
Re: sleeve a 318 and bore to 340 [Re: alpha727] #650774
03/25/10 01:21 PM
03/25/10 01:21 PM
Don't do that Buy a good 360 block and go from there
Re: sleeve a 318 and bore to 340 [Re: Cab_Burge] #650775
03/25/10 01:55 PM
03/25/10 01:55 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
one of my racing buddies has done this. he still tells people it's a 318. at $100 a sleeve you guys pay too much, down here with our $ conversion we're paying the equivilant to $60usd for HD sleeves they fit to diesel bulldozer engines.
Re: sleeve a 318 and bore to 340 [Re: rebel] #650776
03/25/10 02:04 PM
03/25/10 02:04 PM
Stockholm,SWEDEN
The Nutcracker Offline
Stockholm,SWEDEN
My 340 was sleeved on al 8 when i bought it,
Makes stable cylinderwalls. I like the idea of a sleeved 318 stroker, tell people its a stock 318!
-70 Cuda,-65 Valiant,-66 Valiant,-62 FED
Re: sleeve a 318 and bore to 340 [Re: The Nutcracker] #650777
03/25/10 06:14 PM
03/25/10 06:14 PM
Lehigh Acres, Florida
rickstershemi Offline
Supposedly there is a 318 block that was manufactured in the late sixties for two years only that some have successfully taken to 100 over...but can't remember the years or block # .... ??????
Rickster
Re: sleeve a 318 and bore to 340 [Re: alpha727] #650778
03/25/10 08:50 PM
03/25/10 08:50 PM
Lima, Peru
domingo Offline
EL Master
domingo  Offline
EL Master
Lima, Peru
buy a race block. They are not that expensive.
Re: sleeve a 318 and bore to 340 [Re: domingo] #650779
03/25/10 11:39 PM
03/25/10 11:39 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Even if you can get a 340 out of it, you still won't have thicker main journals, or 4-bolt mains like most race blocks have or can be fitted with.
Re: sleeve a 318 and bore to 340 [Re: 340_Dart] #650780
03/26/10 10:18 AM
03/26/10 10:18 AM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I don't know what the industry standard is for remaining wall thickness for dry sleeves < how far you can bore to fit the sleeve> I don't think the sleeve is structurally strong by its self, the sleeves have some benefit in ware from the rings vs the cast iron block but I don't think its a cost effective way to increase bore
Re: sleeve a 318 and bore to 340 [Re: emarine01] #650781
03/26/10 11:39 AM
03/26/10 11:39 AM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
That was what I am thinking... Sleeving a block with the normal type of sleeves will leave material behind to help stabilize things. Removing all the original cylinder material I think would not support the sleeve or deck well enough. Never mind the cost/return issue.
