Hemi tunner, motor bogs #649916
03/24/10 11:14 AM
03/24/10 11:14 AM
new jersey
VryFast Offline OP
VryFast  Offline OP
new jersey
I'm looking for some one in the south jersey area 08080 to get my motor to run right. it's 426 crate motor with dual 4's. Car has never run right, bogs when punching it. Any one know of a good shop in my neck of the woods ?
Re: Hemi tunner, motor bogs [Re: VryFast] #649917
03/24/10 01:05 PM
03/24/10 01:05 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I can guess you have the vacuum advance on the wrong port and when you hit it advance falls off. Unhook and plug vacuum advance for now set timing to 35 total and see how that works.
Leaving vacuum advance off till all tuning and road trials are done (maybe forever!)
Re: Hemi tunner, motor bogs [Re: Dodgem] #649918
03/24/10 03:17 PM
03/24/10 03:17 PM
FOR your hemi.32 degress total is plenty for your combo.
your problem is probably in your metering rods if your running 2 carter carbs.
how far are you from 08050 barnegat or manahawkin?
Re: Hemi tunner, motor bogs #649919
03/24/10 05:04 PM
03/24/10 05:04 PM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
A few more specs on your motor would be nice. What carbs, what intake. What is you timing set at. What Ignition are you running. I would like to know what cam and what it is set at. Things like that. But if you would like someone to look at the car instead of trying to figure it out yourself, talk to SUPERSTOCKRACER.
1971 HEMI E BODY REGISTRY
Re: Hemi tunner, motor bogs [Re: VryFast] #649920
03/24/10 05:18 PM
03/24/10 05:18 PM
I'd check your float levels and if you have a squirt immediately/& duration when you touch the throttle for starters. Vac leak/lean rod & jet combo
Re: Hemi tunner, motor bogs #649921
03/24/10 07:55 PM
03/24/10 07:55 PM
new jersey
VryFast Offline OP
VryFast  Offline OP
new jersey
70 miles I can't fix it myself I need some one to do it.
