broken wheel studs? #649737
03/23/10 11:09 PM
03/23/10 11:09 PM
orange,tx
O
onebadstepside Offline OP
O
orange,tx
I broke the wheels studs off one side of the rear of my truck.The axles are moser with their 1/2inch screw in wheels studs..The rear end is a 8 3/4 with a 4.30sure grip,the rear wheels are weld prostars 15x12 with 31x16 tire.Any ideas on what to look for or any suggestions.The studs broke all at one time.I have all ways had trouble with the lug nuts backing off on the rear.Is there anything special I need to do with big tires?I am clueless on this
Small blocks rule!!!!!
Re: broken wheel studs? [Re: onebadstepside] #649738
03/23/10 11:31 PM
03/23/10 11:31 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would think the wheel was loose a little to shear
them off like that.... are your lug nuts the shoulder
type... if so make sure they arent bottoming out
before the wheel is really tight.... some are very
close and you might think they are tight
Re: broken wheel studs? [Re: MR_P_BODY] #649739
03/23/10 11:35 PM
03/23/10 11:35 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
ARP makes a nice 3" stud. Either that or send the axels back and have them driled for 5/8's studs.
Like Raaff said, check the shank on your lug nuts to make sure they aren't bottomed out giving you a fasle torque reading.
Re: broken wheel studs? [Re: WILD BILL] #649740
03/24/10 01:14 AM
03/24/10 01:14 AM
Raleigh, NC
rockerbob Offline
rockerbob  Offline
Raleigh, NC
I agree, happened to me. Had to get thicker washers.
2005 Dakota 4X4 3.7 2004 Rumble Bee 5.7 1978 Diplomat 318 1969 Satellite 318 "bracket racer" 1966 Barracuda (in progress ) 1964 Dodge 330 (future race project) 1962 Belvedere (HUM????)
Re: broken wheel studs? [Re: onebadstepside] #649741
03/25/10 03:46 PM
03/25/10 03:46 PM
NC
440Jim Offline
440Jim  Offline
NC
One reason is loose lug nuts, that is really hard on studs. Good idea to check the lug nut length, and thicker washers could help.
I like to use a torque wrench to 100 lb-ft. Then after making the first pass, torque them again. They should stay tight after that. Since I rotate my slicks side to side every 20 passes, this gets done often. Otherwise think about checking them periodically with the torque wrench. Maybe every 3 months. It can't hurt to check them at the beginning of each race day if you are having problems with them coming loose.
Re: broken wheel studs? [Re: 440Jim] #649742
03/25/10 04:20 PM
03/25/10 04:20 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
ARP studs with extra long lug nuts
Re: broken wheel studs? [Re: emarine01] #649743
03/25/10 04:30 PM
03/25/10 04:30 PM
MR_P_BODY Offline
MR_P_BODY  Offline
To me you dont need extra long nuts... anything over
the diameter of the stud is just extra material and
more tuning to get it off.... JMO
Re: broken wheel studs? [Re: MR_P_BODY] #649744
03/25/10 05:00 PM
03/25/10 05:00 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
Ok Mike I forgot, We run extra long nuts to keep the mud off the threads
