big block 727 question #649523
03/23/10 09:32 PM
03/23/10 09:32 PM
Michigan, USA
mopar jason Offline OP
Michigan, USA
I picked up a 383 and 727 combo to put in my car last spring. I have finally dropped the motor in the car with the transmission. I needed to finish welding the brackets for the slap stik shifter after welding in new floor pans. I wanted to check the placement of the bracket and I noticed the trans will not shift. The shifter arm on the trans will not budge. So it got me thinking can you shift these cars with out keys in the ignition or am I missing something to make the arm move. I am thinking maybe the trans has sit to long and something inside seized causing the arm not to move. Thanks in advance.
Re: big block 727 question [Re: mopar jason] #649524
03/23/10 09:51 PM
03/23/10 09:51 PM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
You only need the key in the ignition to shift if it is auto on the column. On the transmission itself, you should be able to shift it at will with issues.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
Re: big block 727 question [Re: jrlegacy23] #649525
03/23/10 09:56 PM
03/23/10 09:56 PM
Michigan, USA
Michigan, USA
Thats what I thought so it looks like I am going to have to pull it back out and see whats going on with it. Sometimes it feels like I am not making any progress on this car. Oh well its a hobby.
Re: big block 727 question [Re: mopar jason] #649526
03/23/10 10:18 PM
03/23/10 10:18 PM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
Don't get discouraged, once it is all done, you will be not be disappointed.
Re: big block 727 question [Re: jrlegacy23] #649527
03/23/10 10:21 PM
03/23/10 10:21 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Before you pull it try turning the tailshaft both ways then try shifting it again. You may just be hung up in park.
Re: big block 727 question [Re: mopar jason] #649528
03/23/10 10:34 PM
03/23/10 10:34 PM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
I would suggest moving the trans output shaft ... as you are trying to move the shift lever.
Re: big block 727 question [Re: dOc !] #649529
03/24/10 06:30 AM
03/24/10 06:30 AM
Michigan, USA
Michigan, USA
Going to try to turn tailshaft tonight and see what happens. I didnt think about tryig that. I will let you guys know if it solves my problem.
