Re: big block 727 question
[Re: mopar jason]
#649524
03/23/10 09:51 PM
03/23/10 09:51 PM
Posts: 699 Cooperstown, NY
jrlegacy23
Cooperstown, NY
You only need the key in the ignition to shift if it is auto on the column. On the transmission itself, you should be able to shift it at will with issues.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
[Re: mopar jason]
#649526
03/23/10 10:18 PM
03/23/10 10:18 PM
jrlegacy23
Cooperstown, NY
Don't get discouraged, once it is all done, you will be not be disappointed.
