Black "Crinkle" Finish #648683
03/22/10 11:36 PM
03/22/10 11:36 PM
IL
71383beep Offline OP
IL
I just picked up a stock 71 BB air cleaner. It is in decent shape, but needs to be properly finished to look good.
It had a prior primer job and I am planning on getting it dipped an repainting it. I am curious as to the right materials to do the correct "crinkle" style finish on it.
What have you guys used?
Here's some photos...
'73 GK6 Challenger Rallye - 340 4-Speed
Re: Black "Crinkle" Finish [Re: 71383beep] #648684
03/23/10 12:06 AM
03/23/10 12:06 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I put down a ground coat of satin black, though gloss is fine too. Then heavy coats of the wrinkle-finish black, which requires heat to properly wrinkle. For a consistent wrinkle pattern, you need to play with the heat. Heat gun works, an oven that you don't ever want to heat food in again is even better. Practice on a similar metal that you don't care about first if you haven't done this before.
Re: Black "Crinkle" Finish [Re: topside] #648685
03/23/10 12:25 AM
03/23/10 12:25 AM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
harley davidson engine paint
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: Black "Crinkle" Finish [Re: topside] #648686
03/23/10 12:32 AM
03/23/10 12:32 AM
IL
IL
Who supplies the crinkle paint? Is that easy to get a hold of?
I am curious how the factory did this too...
Re: Black "Crinkle" Finish [Re: 71383beep] #648687
03/23/10 09:18 AM
03/23/10 09:18 AM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
I have a black crinkle powder coating service available. PM me if you are interested and I'll fill you in.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: Black "Crinkle" Finish [Re: 71383beep] #648688
03/23/10 10:17 AM
03/23/10 10:17 AM
30 Rock
JS29 Offline
JS29  Offline
30 Rock
I had a local powder coating company do mine. I think it was $65. Still looks perfect after 7 years or so.
Re: Black "Crinkle" Finish [Re: mopars_1] #648689
03/23/10 11:43 AM
03/23/10 11:43 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
Re: Black "Crinkle" Finish [Re: 71383beep] #648690
03/23/10 12:01 PM
03/23/10 12:01 PM
Ontario.Canada
can.al Offline
can.al  Offline
Ontario.Canada
..i have used the paint from 3 or 4 different companies with good results.
just follow the instructions,it's quite easy.
if you're impatient put it in the hot sun or warm with a hairdryer
Re: Black "Crinkle" Finish [Re: Moparnut426] #648691
03/23/10 03:05 PM
03/23/10 03:05 PM
cumberland co. N.J.
BADDBOB Offline
BADDBOB  Offline
cumberland co. N.J.
harley paint...requires no heat..just spray it on
Re: Black "Crinkle" Finish [Re: JS29] #648692
03/23/10 06:27 PM
03/23/10 06:27 PM
IL
IL
Wow! that looks sweet! I am interested in powder coating though too as an option.
Harley paint too....good ideas all I will look into this a bit more. Thanks
Re: Black "Crinkle" Finish [Re: 71383beep] #648693
03/23/10 09:01 PM
03/23/10 09:01 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
This stuff works great but it must be warm out to get even "wrinkling"...
http://www.eastwood.com/ew-wrinkle-paint-black-aerosol-12-oz.html
