Intake leaking oil? #648297
03/22/10 07:46 PM
03/22/10 07:46 PM
KY
b5a12bee Offline OP
b5a12bee  Offline OP
KY
Oil is getting on my valley pan and is causing my car to smoke pretty bad. I know the heads were milled .040 on the intake side. Should the intake be milled also ? The motor work was done by the previous owner. Is there something I could do with gaskets or permatex? Thanks
Re: Intake leaking oil? [Re: b5a12bee] #648298
03/22/10 07:53 PM
03/22/10 07:53 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
I don't wquite understand what you are saying. Is the oil pooling on the valley tin or is it leaking into the chambers. If it is pooling on the valley tin just put some sealer on the intake bolts. The oil is climbing the threads and is quite common as the bolts really go into open passages in the heads.
Re: Intake leaking oil? [Re: b5a12bee] #648299
03/22/10 07:56 PM
03/22/10 07:56 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
Are your plugs oil fouled?
Re: Intake leaking oil? [Re: b5a12bee] #648300
03/22/10 08:17 PM
03/22/10 08:17 PM
Ft.Myers,Florida
Hemiruss Offline
Hemiruss  Offline
Ft.Myers,Florida
Check 4 vacuum leaks,if the heads were milled,sometimes the intake also needs it.Did you have trouble getting the intake bolts in,like the intake bolt holes were higher than the head intake holes.If they were that could be your problem..
Re: Intake leaking oil? [Re: Hemiruss] #648301
03/22/10 08:49 PM
03/22/10 08:49 PM
KY
b5a12bee Offline OP
b5a12bee  Offline OP
KY
The plugs are fouled. When you first start the car it is fine, if you let it idle for about 5 minutes it starts to smoke out of both sides.
The intake bolts start just fine.
Re: Intake leaking oil? [Re: b5a12bee] #648302
03/22/10 09:13 PM
03/22/10 09:13 PM
Suffolk,VA
I
ireland383 Offline
ireland383  Offline
I
Suffolk,VA
If your getting oil in the chambers you might want to use the valley pan with the paper gaskets on both sides of it. Summit part# 1214 for 383 and 1215 for 440.
Re: Intake leaking oil? [Re: b5a12bee] #648303
03/22/10 09:37 PM
03/22/10 09:37 PM
IMGTX Offline
IMGTX  Offline
Are you sure it isn't working down from the valve covers?
Re: Intake leaking oil? [Re: IMGTX] #648304
03/22/10 09:50 PM
03/22/10 09:50 PM
KY
b5a12bee Offline OP
b5a12bee  Offline OP
KY
valve covers seem to be fine.
Re: Intake leaking oil? [Re: b5a12bee] #648305
03/22/10 10:18 PM
03/22/10 10:18 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Sounds like you will have to remove the intake and reseal,and use a gasket along with the tray as prevously suggested
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
